Old 07-12-2007, 11:25 PM   #11
77celi
77celi is on a distinguished road
pics of fuel injectors, cut harness and the car it's all going in.
ID:	986   Click image for larger version
ID:	987   Click image for larger version
77celi is offline   Reply With Quote
Old 07-13-2007, 01:23 AM   #12
supradaddy0803
supradaddy0803's Avatar
I could hook you up I have a complete harness for a 7MGE sitting on my old motor and it is in good shape the motor has 146000 on it and the I did my 1JZ swap and need to get rid of all of the old parts.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 07-13-2007, 02:57 AM   #13
77celi
What year is the harness? I have a 86.5 it is different than the engine. I need to find out what year my motor is any ideas on how to find that out?
Old 07-13-2007, 12:53 PM   #14
f00g00
Are those plugs for the injectors from the 86.5 harness or the cut harness?
The injectors look yellow to me so might be the JDM ones which won't work on a US harness. Take a look at this link and you can see the difference between the JDM plugs and US plugs.
http://lextreme.com/Injector%20data.htm
US uses plug F and JDM uses E for 7MGE.
If you have the yellow ones you will have to get a set from a junkyard and don't forget to put new O rings on them.
Old 07-14-2007, 12:34 AM   #15
77celi
Last night I noticed that the cut harness on the engine has the plug for the alternator and the 86.5 harness does not. Is there year to year difference between the harnesses?
I can't tell if the injector plugs are different they look the same just different colors.
Old 07-14-2007, 02:12 AM   #16
supradaddy0803
My harness is from a 87 N/A and the plugs on the harness are yellow. Just let me know if it will work for you.
1JZGTE swap
JZA70 Front end mod
Old 07-14-2007, 07:46 AM   #17
f00g00
Your injectors look to me to be JDM injectors which are yellow and will not plug into a US harness unless you remove them and gring the tabs from them.
They also flow less than the US ones.
I attatched a pic of one of mine (nevermind it has sand in it) and you can see the color is light green which is a US version injector.
The Alternater is on a different harness than the ECU so don't worry about that. The oil pressure guage also is separate from the ECU. Your guage cluster won't be the same as the Supras so your going to have to either hook up to a separate guage or go mechanical.
Old 07-14-2007, 08:53 PM   #18
77celi
Ok so I need to get the US injectors, the harness should work with the ECU?
Old 07-15-2007, 01:17 PM   #19
f00g00
If the plugs hook up to the ECU then yes it will work. What type of intake did you get with the motor, is it straight after the throttle body or a Y after it? I didn't see a pic of it.
Old 07-15-2007, 07:51 PM   #20
77celi
It is a Y I took it off so I can get to the injectors.
7MGE to 1JZGTE engine swap help please! seek102287 Non-Generation Specific Questions 2 07-02-2007 12:57 AM
Engine Harness question kidsusukigsxr Non-Generation Specific Questions 0 01-31-2007 05:33 AM
