Old 07-16-2007, 03:00 PM   #11
Supra2NR
Supra2NR's Avatar
Originally Posted by Supra chick's dad
Hey, thanks guys, it's good to hear all the ideas. I did work on the Supra all weekend and came up with some new stuff. I think I found the culprit. First to answer your questions, I did replace the timing belt prior to the install but I've done many in the past. I was extremely careful setting it up right and with the 7M it's as easy as they get. The timing I checked and it was dead on at 10 btdc. I was however able to generate a code by continously trying to get the motor to rev. eventually it crapped out enough to throw a 31. Hanes (cringe) says air flow or ECU. Toyota code book says air flow. Though I had cleaned a grungy MAF already, I decided to go at it again. Upon sterilizing the crap out of the honeycomb, and reinstalling the rest of the assembly, the car revved like normal. I was so freaking stoked! But now it won't idle. Go figure. I guess it's alll good though as the normal symptom for a bad MAF is poor idle. Now that I have seen the changes directly related to the MAF, I am confident the problem lies somewhere within that little black box. 360.00 for a new one seems a bit ridiculous, but neccesary none the less. I need to call around then order one. Too bad there isn't a Supra's only parts store where a guy could get a break on the huge markup. I understand when it comes to aftermarket stuff, but these things can't cost much to make. All the engineering is covered in the cost of the car originally. Whatever, I am on my way and will report after swapping the MAF out with a new one.
if you want,
kurt from elmhurst toyota gives discount to supra owners here in IL
i can pm u his info, if u wanna order it from him
Old 07-16-2007, 03:05 PM   #12
Supra chick's dad
Supra chick's dad is on a distinguished road
Sure, anyhting will help. Thanks!
Supra chick's dad is offline   Reply With Quote
Old 07-16-2007, 08:35 PM   #13
Supra2NR
Supra2NR's Avatar
Curt
630.279.2265 parts direct
630.835.0122 parts fax
eparts@elmhursttoyota.com
My weekly hours are 4:30am-4:30pm M-F CENTRAL STANDARD TIME
there you go, they stock odd parts even for mk3s
and last time i needed sumthing he gave me a pretty good discount
jus be sure to ask for him, and mention supraforums.com
Old 07-17-2007, 05:56 PM   #14
88Tsupra
88Tsupra is on a distinguished road
hey try suprasport.com or driftmotion.com or suprastore.com they all work on supras only maybe you can find a deal on one of those..and are you running the lexus afm
88turbo targa-white
original Pin Stripe
custom intake-Tenzo filter.....Momo racing seats and steering wheel...
apexi exhaust tip-custom 3" piping. Replaced with RSR GT II
NGK plug and wires
HID conversion head lights
HKS Turbo Timer Type-1 (in black)
Tial BOV
BIC DDP
88Tsupra is offline   Reply With Quote
Old 07-17-2007, 06:54 PM   #15
supramacist
supramacist's Avatar
I still dig horsepowerfreaks.com
Old 07-17-2007, 08:41 PM   #16
Supra chick's dad
Thanks on the parts leads. Lexas AFM??? Probably not. This Supra is all stock except exhaust mods. Should I ??? I have a lot to learn on these, I'm old school Chevy guy...
Old 07-17-2007, 09:43 PM   #17
supramacist
Oh you are in trouble Daddy-O.
That's my nic for ya. Don't mess with running lexus parts.
Just make it as mechanically sound as you possibley can.
You may want a new air filter or some plug wires and some hot plugs.
Don't worry about the blaster coil or thw walbro fuel pump or any of that unless you want to.
I think to drive a supra you need a tad bit of ADD so you can do multiple things
and keep switching when you get to stopping points.
Old 07-18-2007, 02:13 PM   #18
Supra chick's dad
Right now I just want it tight. No leaks no mechanical issues. I might swap out the coils to get rid of all that air in the wheel wells, but it has TEMS and I need to read up cause I don't want to trash the ride. It does have some funky mushroom looking foam air filter now, but it will be swapped out for a K&N soon. It is my daughter's ride so she will call the shots on what we do other than the wrenching. She's learning a lot about that too. She knows way more about Supras than I do, just not whenching. Anyone know the best way to drop a couple inches of suspension with TEMS. I don't like cutting coils if I can avoid it as it jacks the ride.
Old 07-18-2007, 05:14 PM   #19
supramacist
Eibach springs. they drop 1.6 inches in front and 1.0 inch in the rear.
Cutting coils is not good. I agree.
Old 07-18-2007, 06:18 PM   #20
Supra chick's dad
Sweet, thanks! It won't alter the Tems I guess as it should just lower the stance. Thanks!!!
Greetings! importauto Import Auto Center 7 06-21-2009 07:42 AM
getaway in stockholm... (i think thats how you spell it) kelogg Road Racing & Autocross 3 06-03-2008 10:53 PM
Lsd RussianMK3 Drifting 6 12-10-2006 05:42 PM
Ghetto is a good seller ARZ Buyer/Seller ratings 0 11-15-2006 11:58 PM
MEET UP's TEAM_Bastos Drifting 0 03-02-2006 09:09 PM
