Old 07-11-2007, 07:01 PM   #1
Supra chick's dad
Supra chick's dad is on a distinguished road
Default Help, no power....
Hey first post here but read a bunch. I put a used Jap motor in my daughter's 89 Turbo Supra as the previous owner han the original out of oil. It all went in real well, and starts right up and idles nicely. However when you touch the gas pedal the rpm drops to 500 rpm's and wants to die. If you let up it returns to a smooth 800rpm's. Cannot possibly get it to rev at all. Here is what I've checked. MAF, TPS, O2, MAP, all connections on the engine harness for bad connections and every pin and socket behind the glove box. Here is what I have noticed, exhaust feels a bit weak at the exhaust tip. I can hold it back without any change in rpm and it doesn't seem to build up a lot of pressure. Small electrical zap when I turn off the ignition and put my hand oth the rocker panel as I get out of the car. This pulse is almost everytime.
Any ideas would be appreciated.....
Supra chick's dad is offline   Reply With Quote
Old 07-11-2007, 07:56 PM   #2
88Tsupra
88Tsupra is on a distinguished road
when u say electrical zap..im asuming you can actually feel it have you check all your ground wire then..
88turbo targa-white
original Pin Stripe
custom intake-Tenzo filter.....Momo racing seats and steering wheel...
apexi exhaust tip-custom 3" piping. Replaced with RSR GT II
NGK plug and wires
HID conversion head lights
HKS Turbo Timer Type-1 (in black)
Tial BOV
BIC DDP
88Tsupra is offline   Reply With Quote
Old 07-11-2007, 08:02 PM   #3
Supra chick's dad
Yes, I have a ground cable fron the neg batt side to the block and the trans to the body and the firewall to the exhaust manifold. All factoy points. I am thinking it may mean something in the electrical system is shorting to ground, but how would you know what and where? I also tried un plugging each sensor while at idle and non of the above mentioned sensors (Except the 02 sensor) made any difference in the idle or ability to rev.
Old 07-11-2007, 10:31 PM   #4
supramacist
supramacist's Avatar
Have ya check'd the codes Daddy-O ???
The codes will tell you exactlly what you need to do.
It sounds like the afm. But hell. It could be a few things.
Old 07-12-2007, 10:53 AM   #5
IHateHacks
IHateHacks's Avatar
There is also a ground on the lower intake manifold. It's brown and white wires going to 1 ring terminal that bolts to the lower intake manifold.
Did you check the ignition timing? Whats it at?
Old 07-12-2007, 01:42 PM   #6
Supra chick's dad
Yeah, checked but there were no codes. I pulled the connector off of the tps while it was running, that threw a code, so I know it's keeping a record. I am thinking the zap is possibly as simple as static electricity as I slide off the seat. I see the car is well grounded and it really shouldn't have electricity running through it at a noticable zap (slight as it is) capacity. I am going to swap out the fuel filter, as I have fuel pressure (38lbs) but might not have enough volume to get it off idle. Also will try pulling the exhaust loose at the ex. manifold to eliminate a blocked cat. Other than that I am at a loss right now. Maybe the ECU??? Where is the best place to get a new ECU anyone?
Greetings! importauto Import Auto Center 7 06-21-2009 07:42 AM
getaway in stockholm... (i think thats how you spell it) kelogg Road Racing & Autocross 3 06-03-2008 10:53 PM
Lsd RussianMK3 Drifting 6 12-10-2006 05:42 PM
Ghetto is a good seller ARZ Buyer/Seller ratings 0 11-15-2006 11:58 PM
MEET UP's TEAM_Bastos Drifting 0 03-02-2006 09:09 PM
