Old 07-12-2007, 05:05 AM   #1
AbsoluteSpeed
AbsoluteSpeed is on a distinguished road
Default ..Rpm's drop until it dies..
So this supra has a nasty habit of idling out as in when I start it if I don’t have my foot slightly on the gas the rpm's drop until it dies, which is kind of a pain with a standard. The old owner assured me that it was because of the missing muffler and a lack of back pressure. It is a family friend that seems to know enough about cars but I would hate to buy it and a new muffler and find out its something else. Does that sound right or do you think that it could be due to something else?
AbsoluteSpeed is offline   Reply With Quote
Old 07-12-2007, 05:18 AM   #2
supramacist
supramacist's Avatar
Run a compression check and pull the codes.
Old 07-12-2007, 05:37 AM   #3
oowee623
oowee623's Avatar
oowee623 is on a distinguished road
happened to me before check for air leaks and tighten your intake clamps
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
oowee623 is offline   Reply With Quote
Old 07-12-2007, 07:05 AM   #4
twerb089
twerb089's Avatar
twerb089 is on a distinguished road
slightly plug the exhaust to simulate backpressure?
1989 supra turbo automatic soon to become a manual
K&N, megan dp, gutted cat, 2 1/2" magnaflow cat back
NA intake cam, shimmed actuator
no A/C or P/S, therefore no ac condensor, compressor and no ps pump or resivior.
gutted interior, 4 tweeters, 2 kicker 12"s powered by an MTX 400W 350rms and an audiobahn 400W 300rms
twerb089 is offline   Reply With Quote
Old 07-13-2007, 02:07 AM   #5
88Tsupra
88Tsupra is on a distinguished road
check your plugs and wire that can be the problem too..that was my problem and yeah check the intake piping as well mines is loose righ now and it does it buh it wont die
88turbo targa-white
original Pin Stripe
custom intake-Tenzo filter.....Momo racing seats and steering wheel...
apexi exhaust tip-custom 3" piping. Replaced with RSR GT II
NGK plug and wires
HID conversion head lights
HKS Turbo Timer Type-1 (in black)
Tial BOV
BIC DDP
88Tsupra is offline   Reply With Quote
Old 07-13-2007, 07:11 AM   #6
AbsoluteSpeed
Thanks for the suggestions I will check see what i can do.
Old 07-13-2007, 01:36 PM   #7
west_side_supra
west_side_supra's Avatar
hmmm, well id agree with everyone above, check the intake pipeing, IC pipeing if its turbo'd. also check all vacume hoses. a lacking muffler wouldnt cause it to drop the rpms hell alot of us are running with no cats and 3 inch pipeing and have no problems at all. if the muffler is plugged i doubt it would cause that kind of problem, if thats the case just chop it off. and put an exhaust tip on it. its not missfireing at all? any codes? <<< you need to put a paper clip or wire or somthing inbetween termainals T and E1 of your diagnostics box in your engine compartment... does it have the stock Bypass valve?
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 07-13-2007, 02:42 PM   #8
supramacist
The tweezers from your swiss army knife, lol.
I used a 2 inch piece of 18 gauge wire that I used to wire in the Blaster coil.
Old 07-14-2007, 07:35 AM   #9
If it's not going into idle properly check the IDL switch in the TPS and test the ISC.
engine cuts and dies uddinf MKIII Supra 9 09-06-2009 06:56 AM
1986.5 Idling at high RPMS Sasukevh MKIII Supra 2 06-14-2007 04:56 AM
Start up and engine dies. Drag0na5h MKIII Supra 12 01-14-2007 02:04 AM
rpms dropping Supra1989 MKIII Supra 0 05-01-2006 02:50 AM
Sputter @ high rpms with pedal all down! MKIIISupraTurbo Non-Generation Specific Questions 2 11-11-2005 01:47 AM
