Old 07-12-2007, 08:40 PM   #1
go.stfu
go.stfu's Avatar
go.stfu is on a distinguished road
Default Crank Pulley Removal
The crank bolt is out but I can't get the crank pulley to budge even a little.
I've tried prying it off from every angle with an assortment of tools.
I don't have a puller.
Any suggestions appreciated,
Thanks.
1985 manual (r.i.p) -- 1989 automatic (new)
http://www.cardomain.com/ride/2635827
go.stfu is offline   Reply With Quote
Old 07-12-2007, 10:11 PM   #2
IHateHacks
IHateHacks's Avatar
Get underneath the engine with 2 big flathead screwdrivers one on the left side of the pulley and one on the right. And "walk" it off a little at a time, don't pry too hard or you will crack the lower aluminum timing cover. It will take you a while, took me 20 minutes to remove my pulley that way, but it works and costs a lot less than the SST. Work at it for 5 minutes and get up and look how far the pulley has moved away from the lower timing cover, look where the timing marks are and you'll see it move a couple millimeters at a time. Just take your time.
Old 07-12-2007, 10:22 PM   #3
go.stfu
go.stfu's Avatar
I'm trying that at the moment (and it's going very slowly) heh.
Thanks for the info.
Old 07-12-2007, 10:42 PM   #4
supramacist
supramacist's Avatar
Jeez this sounds familiar.
I think this one cost me 300 bucks to replace.
Be ginger with it, seriously. They are a limited toyota only part.
After I broke it....., it was still a bitch to get off.
But I did what HH is saying to do.
Old 07-12-2007, 11:16 PM   #5
go.stfu
go.stfu's Avatar
Been working at it for over an hour and it seems to have moved half a centimeter on one side and nothing on the other. It refuses to move any more. Any more ideas or am I fkd?
1980 Supra Crank Pulley (Harmonic Balancer) steve6163 Non-Generation Specific Questions 7 06-18-2010 01:47 AM
crank shaft pulley puller supramacist MKIII Supra 30 04-18-2007 02:27 AM
Main pulley removal. Kuban MKIII Supra 17 03-19-2007 07:04 AM
Crank shaft pulley.. MA70_858 Non-Generation Specific Questions 3 07-28-2006 04:47 PM
Crank pully removal G-string MKIII Supra 7 05-07-2006 11:09 AM
