Old 07-19-2007, 05:47 AM   #11
Don't ditch the charcoal canister, if anything replace it with a smaller one from a newer vehicle. It gives the gas that would other evaporate out of your tank somewhere to go until it can be used by the engine.
As for the EGR removal, if you're doing for looks, fine. But it also helps reduce your combustion temps and has been proven on the dyno to make no noticeable performance difference whatsoever.
Old 07-21-2007, 07:22 AM   #12
zuni
zuni's Avatar
zuni is on a distinguished road
Arrow
Originally Posted by gpgtp_22
Dont forget to cap the bvsv on the water neck too.
where is that located at?
zuni is offline   Reply With Quote
Old 07-21-2007, 09:24 AM   #13
The bvsv is part of the charcoal canister's system (evaporative emmissions control). You don't need to remove that or the charcoal canister unless you like gasoline vapor in you engine bay or just evaporating out of your tank. Dunno about you, but i'm dead set on burning every 10th of a cent worth of gas I buy these days... a few years ago I may have felt differently.
Old 07-21-2007, 05:44 PM   #14
gpgtp_22
gpgtp_22 is on a distinguished road
It is on the thermostat housing it has two vacuum fittings coming off of it
gpgtp_22 is offline   Reply With Quote
Old 07-03-2015, 05:45 PM   #15
BadRiggins
BadRiggins is on a distinguished road
I got a 1989 Supra because my friend wouldn't pay me back. It had a blown head gasket when he got it. He did that work himself, I'm a little worried about that, haha. But he also did the egr/canister delete.. As well as he got rid of the 25719 tank "vacuum surge" with maybe a few other things.. I don't know if those can be taken out or not? And if not, will that stop the car from running/starting?
Originally Posted by west_side_supra View Post
well i did some searchese this is what i found
http://toyotaownersclub.com/forums/i...howtopic=39095
http://www.supramania.com/forums/showthread.php?t=386
7mgte removal of charcoal canister and EGR
Now remove the vacuum hoses that are highlighted in red. And cap off the vacuum ports that I highlighted in green. That’s all there is to it for a stock setup.
as for the blocking off i was reading a little more on this, if i got this right the right red circle you want blocked off. but as for the right one you dont want to block off, the 2nd block off goes onto the intake plenum heres a pic of that
7mge removal of charcoal canister and EGR
Same thing as before. Red are the vacuum lines you can remove and the green is the places to cap. And the blue dots are pieces that you can remove.
"NOTE"
i got all this information from other peoples post, so dont try to think im smart
BadRiggins is offline   Reply With Quote
Old 07-04-2015, 11:25 PM   #16
mirage83
Sounds like a bunch of people have no idea how the EGR works or what it actually does.
Cre is correct, it serves a valid purpose and does not adversely effect performance in any meaningful way. Unless of course you're relying on the data from your ass dyno.
Old 07-05-2015, 02:16 PM   #17
JIMMY JO BOB
JIMMY JO BOB is on a distinguished road
Thumbs up
CORRECT - Personally I do delete the connections at BVSV & just run Vac line fm Evap Can direct to Vac Port on Intake.
87 NT
JIMMY JO BOB is offline   Reply With Quote
engine removal mizuboi MKIII Supra 11 06-10-2011 06:25 AM
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
86.5 auto transmission removal HELP!!! elmer MKIII Supra 13 04-06-2010 10:41 PM
Fuse Removal + Nice Supra Pic jdbones Non-Generation Specific Questions 0 01-28-2008 01:01 AM
Is this true? Fuse removal can change limiter jdbones Non-Generation Specific Questions 0 12-30-2007 10:31 AM
