Old 07-13-2007, 06:30 PM   #1
gpgtp_22
gpgtp_22 is on a distinguished road
Default EGR removal
I have an 90 turbo and I am looking to remove the whole egr system. What all do i need to take off/cap etc. and will i run into any problem doing this. I think I know mainly what to remove but i want to be sure i get everything. If you could tell me where things are located to save me some time with the tsrm that would be great too. Thanks!
gpgtp_22 is offline   Reply With Quote
Old 07-14-2007, 10:41 PM   #2
mrnickleye
mrnickleye's Avatar
If you ever need to smog test the car, you will need the EGR in place.
Tell us the story behind this.
WHY do YOU feel you need to remove it??
Old 07-15-2007, 05:16 PM   #3
gpgtp_22
I live in Wisconsin so i dont need to smog test. I want to clean up the engine bay and i dont like the idea of all that going back into my motor. It is also one more thing that can go wrong down the road. I dont feel like i need to at all i just want to get rid of it reduce clutter, vacuum lines etc. I just took the egr caps off a jdm 7m i have and then im going to cap the vacuum lines.
Old 07-16-2007, 06:57 AM   #4
west_side_supra
west_side_supra's Avatar
he does have a point, i have heard alot of you guys telling me to check my EGR valve because it might be stuck open or somthing along those lines, getting rid of it would fix that problem, hell id get rid of it if i knew how to
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 07-16-2007, 06:15 PM   #5
twerb089
twerb089's Avatar
twerb089 is on a distinguished road
i would love to remove the EGR, but i live in CALI and all the tree hugging hippies out here would rape me..
egr is the stupidest thing on the vehicle.. re-routes exhaust gas into the intake to reduce emissions and power. hot air intake FTL
1989 supra turbo automatic soon to become a manual
K&N, megan dp, gutted cat, 2 1/2" magnaflow cat back
NA intake cam, shimmed actuator
no A/C or P/S, therefore no ac condensor, compressor and no ps pump or resivior.
gutted interior, 4 tweeters, 2 kicker 12"s powered by an MTX 400W 350rms and an audiobahn 400W 300rms
twerb089 is offline   Reply With Quote
Old 07-16-2007, 07:20 PM   #6
west_side_supra
so then how would us guys who dont have to do emmisons remove this EGR crap, yea i know damn them tree hugging bastards im plannin on movin to cali haha. they'll love me down there. although my car will be registered still down here in washington so i dont think ill have to.
fidenza cam gears
Old 07-16-2007, 07:23 PM   #7
west_side_supra
well i did some searchese this is what i found
http://toyotaownersclub.com/forums/i...howtopic=39095
http://www.supramania.com/forums/showthread.php?t=386
7mgte removal of charcoal canister and EGR
Now remove the vacuum hoses that are highlighted in red. And cap off the vacuum ports that I highlighted in green. That’s all there is to it for a stock setup.
as for the blocking off i was reading a little more on this, if i got this right the right red circle you want blocked off. but as for the right one you dont want to block off, the 2nd block off goes onto the intake plenum heres a pic of that
7mge removal of charcoal canister and EGR
Same thing as before. Red are the vacuum lines you can remove and the green is the places to cap. And the blue dots are pieces that you can remove.
"NOTE"
i got all this information from other peoples post, so dont try to think im smart
fidenza cam gears
Old 07-16-2007, 08:40 PM   #8
Supra2NR
Supra2NR's Avatar
this type of things makes me glad i took my egr b4 i put the engine back,
cuz its pretty hard to get tools back there
or maybe im jus clumsy like that
Old 07-18-2007, 06:05 PM   #9
gpgtp_22
Thanks a lot guys i'm definately capping those when i put my head back on. The visual was a big help. I was lucky i had a jdm engine with the block off plates sitting around that i could "borrow". I agree egr worst idea ever.
Old 07-18-2007, 06:07 PM   #10
gpgtp_22
Dont forget to cap the bvsv on the water neck too.
engine removal mizuboi MKIII Supra 11 06-10-2011 06:25 AM
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
86.5 auto transmission removal HELP!!! elmer MKIII Supra 13 04-06-2010 10:41 PM
Fuse Removal + Nice Supra Pic jdbones Non-Generation Specific Questions 0 01-28-2008 01:01 AM
Is this true? Fuse removal can change limiter jdbones Non-Generation Specific Questions 0 12-30-2007 10:31 AM
