Old 07-13-2007, 08:04 PM   #1
V1P3R
V1P3R is on a distinguished road
Default 2 Questions: 1 About Overheating, 1 About HeadUnit Adaptor
Ok ill start with the easier question first,
Anyone know where I can get an adaptor for the console that will hold a CD player instead of the stock radio? Right now I just have my headunit resting there. Also the headunits heatsink, at least I hope thats what it is, is getting hot and im afraid if it hits the wires it will melt them. Im already getting some slight connection issues from time to time with flickering/etc.
2nd and more difficult question.
Ive had my car for a couple days now, 1989 NA 5speed 190k miles. When I got it, it hadnt been driven for a year or so. Needed a new water pump which I replaced. It was then driveable, and after a tune up and some little parts here and there it was ready to go.
Driving on the highway I realized it was overheating after 20-30 mins of 60+mph. The RPms were at about 4k or so from what I remember, and the cars engine sounded loud. But I just figured thats how these cars run.
Anyways, I replaced the thermostat, then did the whole HG job which was a royal pain in the __. That still didnt fix the problem. Next I tried flushing the system incase of any air pockets/bubbles. STILL overheated on the highway. Radiator cap looks ok too.
Weird part is, it only overheats on the highway. If I keep it under 60 mph, it wont overheat. That is unless I drive it a little harder, then it will run hot. But when I granny drive it, it doesnt overheat.
Also I noticed, if I drive it at about 50-60 for 20 mins or so, sort of agressively, and then drop down to 20-40, it seems to almost immediately begin to overheat and run hot. It didnt when I was at the 50-60, but when the speed decreased it ran hotter, which may make sense since I was in a lower gear, but my RPMs might have been the same.
In any matter, im hoping this isnt still a faulty HG, im not sure what else it is. I seem to have a lot of problems with overheating since my other car which is a 94 Eagle Talon, also had a bad water pump and thermostat, and now needs a new engine due to a crack in the block.
Is there any opinions out there as to what I should do? The car drives fine all day long at low speeds, it gets me around fine and sounds and drives beautifully. The car does slightly burn oil, but not badly at all. Coolant and oil levels are normal.
Thanks in advance for any help!
V1P3R is offline   Reply With Quote
Old 07-16-2007, 03:14 AM   #2
V1P3R
?? Can anyone help me out here??
Old 07-16-2007, 04:24 AM   #3
supramacist
supramacist's Avatar
What are you running as coolant?
Is there oil in your overflow cannister?
What is it about the engine that seems loud?
Can you see into the radiator? Is it covered with crap or is it clean?
When you top off the coolant is it always low and by how much?
Are you running stock hose clamps?
Is your fan shroud in good shape?
How's your fan clutch?
Are you smaller fans working?
Old 07-16-2007, 05:15 PM   #4
V1P3R
Originally Posted by supramacist
What are you running as coolant? It was a 50/50 mixture before, and since the last time it overflowed and I lost fluid, I have replaced it with straight antifreeze.
Is there oil in your overflow cannister? I dont believe so, I will check again but I dont think so.
What is it about the engine that seems loud? Its just a normal engine sound, nothing that sounds out of the ordinary. I just think I was so used to driving cars that were quieter that this seemed louder. Its just at 4K+ RPMs it seems loud to me. But my car sounds loud stock, not the exhaust, but the engine itself. It idles and drives smoothly so I dont think there is any problem there.
Can you see into the radiator? Is it covered with crap or is it clean? Radiator is clean from what I can see of it.
When you top off the coolant is it always low and by how much? When I topped it off last it was only low a half-liter or so, nothing much at all.
Are you running stock hose clamps? I believe so, the car has only had 2 owners before me, and one didnt do anything to it, the car just sat in his driveway for years. The person before that was an elderly lady, so I would think they are stock. I will check.
Is your fan shroud in good shape? Yes fan shroud appears to be in fine condition.
How's your fan clutch? Sorry but im not familiar with this? What exactly is this and where is it located?
Are you smaller fans working? Where would these smaller fans be?
Thanks for the reply, im not a big gear head so I apologize for my naivety on some of the parts. Appreciate the help so far!
Old 07-16-2007, 06:13 PM   #5
twerb089
twerb089's Avatar
twerb089 is on a distinguished road
your fan clutch it the aluminum piece between your fan and water pump. to test it get the car hot and turn it off, you should not be able to turn the fan.
the smaller fans are for the A/C, which wouldn't really have anything to do with an overheating problem.
is there sufficient flow to the radiator? like is there shit in front of it that would cause it to get no airflow?
1989 supra turbo automatic soon to become a manual
K&N, megan dp, gutted cat, 2 1/2" magnaflow cat back
NA intake cam, shimmed actuator
no A/C or P/S, therefore no ac condensor, compressor and no ps pump or resivior.
gutted interior, 4 tweeters, 2 kicker 12"s powered by an MTX 400W 350rms and an audiobahn 400W 300rms
twerb089 is offline   Reply With Quote
Old 07-16-2007, 10:14 PM   #6
supradaddy0803
supradaddy0803's Avatar
The head unit adapter that your looking for you can get at wal-mart and even best buy. It is a multiple adapter that fits pretty much all toys just look for the year and fit on the back. As for the wireing harness pigtail that I recommend you get you can get it the same place.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Questions about the oem fuel system Magical Trevor MKIV FAQ 7 08-19-2007 04:40 PM
new here, few questions SoooopRa! MKIII Supra 6 08-29-2006 11:25 AM
newbie questions erik MKIII Supra 4 01-10-2006 11:37 AM
