-   -   first supra (http://www.toyota-supra.info/forums/mkiii-supra/9104-first-supra.html)
thenoob 07-20-2007 12:46 AM
first supra
ok so i'm looking at buying a my first supra. Although i'm most probably going to get a '95 or so tt next year i'm starting smaller for my first. I'm looking a older body style, like a '90 to '92 model, non-turbo. I'm wanting to get some info before i buy it because i'm wanting to build it up. I was wondering if they make turbo kits for it, i haven't found any but maybe i'm looking in the wrong places. I want to build it for about 600 or so horsepower, if thats possible on that model. i'm looking to build the block and head, but i was wondering if a turbo kit was sold for this model or one ahd to be built. or should i do somesort od swap? also the car is an automatic. i thank you guys in advance.
88Tsupra 07-20-2007 04:15 AM
if your looking for 600hp on a NA motor you better off finding a turbo model..and if you did ur reseach you know the 7m-7mgte all have the Head gasket..if you type kwnate in search you will see his 845whp i think on a 7mgte its easier said then done
but go turbo righ away with the car unless u got money in the bank and can do a 1jz or 2jz swap right away
suprascoot 07-20-2007 04:22 AM
You would be much better off just finding a turbo model to start your work on. As of yet I havn't come accross a turbo kit for a n/a supra.
j3pz 07-21-2007 02:01 AM
the mk3 (86.5-92) and mk4 (93.5-98) are two totally different cars. they are similar but def different. learning about the mk3 wont help learn about a mk4. i can underestand learning about the mk3 to understand car s and motors better. but w/e :dunno:
thenoob 07-21-2007 11:31 PM
hmm. ok i'll probably just try to find a turbo model.
ddmcse 07-24-2007 01:19 PM
BHG- learn this term
