Old 07-23-2007, 12:51 AM   #1
justin1642
justin1642's Avatar
justin1642 is on a distinguished road
Default Speedometer Does Not Work!
ok i changed my speedo cable both long and small ones and still the speedometer does not work. So would it be my entire cluster? or would the plug be bad on the harness? and if it is the cluster and i have to buy a used one on ebay or whatever, does it matter that the milage on the cluster won't match mine?
justin1642 is offline   Reply With Quote
Old 07-23-2007, 08:11 AM   #2
f00g00
The problem with the speedo cables is that if they freeze up they can ruin the gear in the transmission. This gear is made of plastic and gets rounded out in the middle so it is probably bad. You can pick one up at the dealer for fairly cheap, mine was less that 30 dollars and came with a C clip and the oil seals. I had a mechanic crawl under there and change it so I didn't see how it was done.
Old 07-23-2007, 09:12 AM   #3
The speedo drive gear is held in by a little bracket and one bolt. It's cake, but you'll need to drain the tranny first or you're going to end up a whole new level of greasy and smelly.
Old 07-23-2007, 02:51 PM   #4
justin1642
justin1642's Avatar
ok i changed the small one a while ago(like 2 months) but the long one i changed yesterday and it was still good when i took it out but still changed it when it was out anyway. even with the cables still good the speedo just went out one day. so do you still think the drive gear seized up? or possibly something else?
Old 07-23-2007, 02:55 PM   #5
justin1642
justin1642's Avatar
also does anyone have a pic of where it is cuz i have no idea and how much do you think it would be for a shop to do it?
Old 07-23-2007, 06:33 PM   #6
justin1642
justin1642's Avatar
i called toyota and the part cost $26 someting and they said it is $46 if its at the end of the cable and $225 it its in the transmission. so what one do you guys think it is? any help is appreciated thanks.
Old 07-23-2007, 08:16 PM   #7
f00g00
Its the one at the end of the cable in the transmission, the one the cable connects to.
Pop off the cable and spin it, you should see a slight deflection on the speedometer. You might even try and move it wirh a cordless screwdriver on low speed but Ive allways been able to see something by spinning the cable by hand.
Old 07-23-2007, 10:34 PM   #8
Another possibility is the speedo itself.
Old 07-23-2007, 10:56 PM   #9
justin1642
justin1642's Avatar
ok i think i'm going to take it to toyota they said they'll look at it and tell me whats wrong for $27 so i can handle that. thanks for the help if anyone can think of anything else please keep posting.
speedometer drive gear removal Gunnar MKIII Supra 1 01-20-2008 08:24 PM
N20 and HeAd WoRk Supra_87_mk3 Non-Generation Specific Questions 4 05-25-2007 03:09 PM
Dash lights Don't Work supra67 Non-Generation Specific Questions 4 09-05-2006 04:58 AM
Dash lights Don't Work!! supra67 MKIII Supra 0 08-10-2006 01:11 AM
Speedometer help HottScennessey MKIII Supra 1 03-19-2005 06:59 AM
