Old 07-24-2007, 12:16 AM   #1
Jeff_5_7
Jeff_5_7's Avatar
Jeff_5_7 is on a distinguished road
Default OBX header
ok i got an obx header off ebay and i installed it and redid my exhasut all the way back from the cat my cat is cleaned out now my exhaust back fires how can i fix this and also my car dosnt run very good now i think cus the timing is a little off or could it be cus the o2 sensor isnt hooked up
Supras anrt ricers there Japanese Muscle
1988 supra n/a just finsihed 5 speed swap
goal is 400hp with a turbo motor swap
Jeff_5_7 is offline   Reply With Quote
Old 07-24-2007, 01:27 AM   #2
supramacist
supramacist's Avatar
Both of those dude. Your 02 sensor has to be plugged up or it just won't get up right.
Old 07-24-2007, 01:59 AM   #3
j3pz
it will run like crap with either of the two... but i dont think that a loose/non-existing o2 sensor will cause a back fire
Old 07-24-2007, 05:20 AM   #4
supramacist
The backfire is a by-product of poor timing.
Old 07-24-2007, 08:16 AM   #5
f00g00
The O2 isn't electrically connected or there is a hole where its supposed to be installed?
It needs to be installed to run properly so the ECU can adjust the fuel air mixture. It plays a large role in how the car runs, its the only thing that feeds back to the ECU when everything else sets up for whats going out of the motor.
Did the new headers bolt right up or did you have to grind anything?
Im also thinking of getting OBX's, my pace setters had to be heavily modded to work and I think ceramic coating will be better than my wrap job.
Old 07-24-2007, 11:38 AM   #6
west_side_supra
west_side_supra's Avatar
i dont know my car back fires but its just because of my blow off valve not shutting fully nothin better than a little 4" fireball out da back to piss the guy off riding your a$$
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 07-25-2007, 11:01 PM   #7
supra_91
supra_91's Avatar
you dont have a blow off valve if u dont have a turbo. im assuming you dont bc u bought the obx headers
Old 07-26-2007, 04:20 AM   #8
j3pz
was jsut thinkin about it... if the o2 sensor is connected, but not in the hole/loose, it may be reading for o2 than what the motor is putting out, thus advancing/retarding the timing, trying to burn the o2. this could also cause the backfire, correct? if im wrong i want someone to say so, dont wanna be putting false info out there.
Old 07-26-2007, 05:47 PM   #9
Jeff_5_7
Jeff_5_7's Avatar
obx header bolted right up but 2 days laster the head gasket blew outta the motor so i wanna get a turbo motor now
PaceSetter Header wa-mkIII MKIII Supra 4 11-30-2008 08:03 PM
Header help! shiftysupra MKIII Supra 0 09-16-2008 11:47 PM
header question jride1999 MKIII Supra 7 04-04-2008 01:09 AM
7mgte Header teedoff00 MKIII Supra 0 05-18-2007 05:14 AM
header supra_91 MKIII Supra 4 04-13-2006 10:36 PM
