Old 07-25-2007, 02:09 AM   #1
Chambers
Chambers's Avatar
Post Gas cap cover not opening!
Hi all, my gas cap cover isnt opening now, it hasent been that bad i just proped the latch up and opened the cover manually, but for the passed two days i had to have someone open it while i held the latch. I was wondering what i could do to get the cover to open smoother? Thanks.
Old 07-25-2007, 02:51 AM   #2
plaaya69
plaaya69's Avatar
plaaya69 is on a distinguished road
Use some WD-40 and bend the spring so that is will give you more of a opening.
1987 Toyota Supra Turbo-burgundy exterior w/gray interior+1987 Toyota Supra(N/A) light brown top,dark brown bottom w/light brown interior.
plaaya69 is offline   Reply With Quote
Old 07-25-2007, 03:11 AM   #3
Supra2NR
Supra2NR's Avatar
when that happend to me,
the small piece of metal that acts as a spring to pop the cover oven
had a crack on it and got worst everytime i opened it
it will only be a matter of time b4 it completely screws up on you
so try to go to the junkyard and get another one
thats what i did
and plus the cover fits in ur pocket (junkyard rules)
Old 07-25-2007, 04:17 AM   #4
Chambers
Chambers's Avatar
Yea iv been using wd40 and bending the spring and that hasent worked. There are no Supras around at the salvage yards ive checked so far, so im stumped for parts but i have an idea on how to fix this, if it works i post it. Thanks for all the help.
Old 07-25-2007, 05:29 AM   #5
dannydavi
dannydavi's Avatar
might be something down by driver seat where you push the lever, i also have to fix mine. I was messing around down there when fixing my back hatch and after i assembled everything i noticed it wasnt working anymore, now i have to manually do it from the back.
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 07-25-2007, 10:15 PM   #6
Chambers
Chambers's Avatar
Well i thought that was the prob but the cover opens when i hold the latch. This morning i put a little bit of electrical tape around the spring and at the pump it flew open, im going to let it sit for a while and see if still works.
Replacing my vavle cover gasket mkiiisupra MKIII Supra 0 11-18-2008 06:50 PM
valve cover gasket question? sevenmgte MKIII Supra 8 10-01-2008 06:02 AM
Rear Hatch Cover, retractable scorpmatt MKII Supra 4 01-30-2006 05:12 AM
Timing belt rubbing against lower front cover adamh88 MKIII Supra 4 01-05-2006 11:08 PM
