Old 07-21-2007, 07:40 AM   #1
zuni
zuni's Avatar
zuni is on a distinguished road
Arrow Cruise Control
does anyone know if it is ok if i remove my cruise control from my car. i have a 89 supra turbo 7mgte. i dont use it or need it. is there any thing that can go wrong. any ups and downs to doing this.
zuni is offline   Reply With Quote
Old 07-21-2007, 10:38 AM   #2
SupraDupra
SupraDupra's Avatar
I took mine off without any problems. The cable looked a little rough and I never use it either so I just took it off.
1988 Supra - N/A 5 speed
1974 'Cuda - 318
2001 Cherokee
Old 07-21-2007, 12:55 PM   #3
supradaddy0803
supradaddy0803's Avatar
I had to remove it it just didnt fit with my 1JZ. That and who needs cruise on a hot rod. Just like the a/c on the motor if I can find a shorter belt I would remove the a/c compressor.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 07-21-2007, 09:05 PM   #4
f00g00
Just remember to cap the vacuum hose or get rid of the Tee fitting and run a straight hose to the heater valve.
Old 07-25-2007, 03:12 AM   #5
zuni
zuni's Avatar
Arrow
where can i find something to cap the vacuum hose with.
Old 07-25-2007, 03:15 AM   #6
Supra2NR
Supra2NR's Avatar
why do u need a shorter belt?
is it one whole belt on the 1j?
Old 07-25-2007, 03:55 AM   #7
supramacist
supramacist's Avatar
Just take a string and measure.
Go to your local parts house and order that length.
Old 07-25-2007, 08:23 AM   #8
f00g00
You can run a 4 foot hose through the firewall and plug it with your finger if you want, j/k.
Just run a single hose which you should do anyway if its coming out permanently.
Old 07-25-2007, 03:20 PM   #9
supradaddy0803
Yes the 1JZ is a single belt just the same as the 2JZ actually the same length too. I did that yesterday need to find the part number and post it on here that way everyone that wants to can do the same.
1JZGTE swap
JZA70 Front end mod
Cruise Control Button Config. Question Chambers MKIII Supra 2 09-07-2010 04:20 AM
Cruise Control carfanatic89 MKIII Supra 5 09-06-2007 08:44 AM
Cruise Control, Help Please! Al Hanks Non-Generation Specific Questions 0 03-19-2007 07:22 PM
cruise control and other problems... castle77 MKII Supra 6 10-14-2005 03:39 AM
