turbo swaps
Ok i have just bought a 1986.5 non turbo auto. I want to know,can I put a aftermarket turbo on it with minimal mods. Is it worth the gain. How do i remap my computer. When I put a turbo on it.
since the n/a has higher compression pistons oil squirters on the block untapped return line, and so on and so fourth |
will that meen i have to change the wiring harnes. I'm sure i have to change the ecu. but will all of this "plug and play" with the na engine.
one more question about this were an i fine this engine and what are the average cost and whats the horse power.. thanks or all the help guys |
average hp 180hp to the wheel
average price i wouldnt pay more then 400 even if average reason why people sold their 7mgte BLOWN HEADGASKET you can get the 7mgte and before putting it in fix the head gasket right away dont wait if money isnt that tight for you try gettin a 1jz they average about 2k an engine meanign with front clip motor and tranny if money is just paper to you 2jz can be your answer average price on that is 6500 |
but if ur getting the 7mgte, u better be sure to get the little things too ie: coil pack, igniter, harness, ecu, power steering mount, intercooler, throttle body housing, TB cable and try to get the r154 trans too, the NA trans will bolt up, but the 154 is more robust, and can hold more power |
ok just a little about this care, it has been sitting for about 2-3 yrs. when it was parked it had a small rear main seal leak but thats getting fixed. once thats done what are a few thing i can do on my military pay to make this car a little more powerful. hey thanks for the help man
