Old 07-27-2007, 01:26 AM   #1
hkssupra
hkssupra is on a distinguished road
Default how high can you go?
hello everyone, new to forum, i have a 87 supra that i have been working on for quite a while now, i just recently drove it for the first time and when i hit full boost, i was only at 5-6 lbs. the car has a manual bc, do you think possibly it could be bad? i had it turned up to about 10-15 lbs, i know its not my charge pipes or vacuum leaks so this is the only thing left i can think of. Also i was wondering how high i can boost safely. the car has- hks f-con,fcd, stock pipes and intercooler, hks bov, and straight threw exhaust(hollow cats) and greddy muffler. what psi do you think ill be safe running? any help is appreciated..thanks
hkssupra is offline   Reply With Quote
high idle 3.0trd MKIII Supra 4 04-27-2008 03:37 PM
Headlights only work on High Beam - is it a fuse? t4yl0r10 Non-Generation Specific Questions 8 01-18-2008 03:56 PM
Speedometer, High RPM/Speed whine, High HC's 88 N/A ravenmaster MKIII Supra 8 08-13-2006 12:02 AM
