Old 07-29-2007, 04:46 AM   #1
ethan12510
ethan12510 is on a distinguished road
Default Brake light Help
okay so my brake light is on even when the parking brake isnt how do i fix this? im thinking a bad sensor? thanks
ethan12510 is offline   Reply With Quote
Old 07-29-2007, 06:22 AM   #2
Somajunkie
Somajunkie is on a distinguished road
I've got the same problem too, but I've just learned to live with it. I think that part of the car was just horribly manufactured
Somajunkie is offline   Reply With Quote
Old 07-29-2007, 07:08 AM   #3
f00g00
There are two lights on the dash that deal with the brakes. The yellow one deals with faults like having a bad bulb it will come on to tell you that there is a problem when you step on the brakes. In my case I need to change the yellow box tucked into the rear drivers side brake lite panel. Sometimes the lights can be working fine but the box just decides to go bad and say there is a fault when you step on it.
The red one underneath which comes on when you put on the E brake is also on when the fluid gets low in the brake master cylinder so pop the top and see where the fluid level is and if its full make sure the float inside hasn't gotton full of fluid and sank. Most likely it just needs to be topped odd a little.
Also check the wires and make sure they didn't get shorted together somehow.
Old 07-29-2007, 07:55 PM   #4
Wink
Yea...but only "your" car. I've had mine as a daily driver for 5 years with NO such problems.
Old 07-31-2007, 02:57 AM   #5
ethan12510
thanks just need a lil fluid
Brake light failure... RNEMESiS42 MKIII Supra 17 08-10-2008 12:53 AM
Spoiler Brake Light Info Bill UK MKIII Supra 0 10-27-2006 10:06 PM
Hand Brake Light 88Supra Non-Generation Specific Questions 8 08-18-2006 01:35 PM
1995 Supra Brake Light Malfunction??? johnlijo Non-Generation Specific Questions 2 02-27-2006 05:17 AM
