Old 07-30-2007, 11:13 AM   #1
west_side_supra
west_side_supra's Avatar
Default Greddy BOV issue
ok first of all as you might know im doing about 10-11psi and on a rare time 12psi. but also some of you have seen the new IC pipe setup i have going. but my main issue is that my Greddy RS BOV is opening at around 4krpms during load. so driving on the freeway i can hear it whisteling while im driving. what you guys think i should do about this problem?
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 07-31-2007, 07:09 AM   #2
Are you sure it's the BOV and not a leak from the flange? Otherwise, I'd take it apart and either get the spring tested or just replace it.
Sorry, I don't know too much about the mechanics of a BOV.
Old 07-31-2007, 08:49 AM   #3
west_side_supra
yup im sure its the bov, just because i can see the valve opening. the gasket is fine. sping tested WHAAA? replace it with what i dont think you can replace it. i think im screwed with getting another one HAHA
fidenza cam gears
Old 07-31-2007, 09:06 AM   #4
Trust me on this: Don't take my word for it... get a second opinion.
Greddy BOV Intenseneal MKIII Supra 7 09-02-2005 10:15 PM
