-   -   Has anyone done this? (http://www.toyota-supra.info/forums/mkiii-supra/9235-has-anyone-done-this.html)
Chambers 08-04-2007 07:48 PM
Hi all, I was wondering if anyone out there just stuck a turbo on a NA and ran it so see what happens. Because there is a local shop that has a 87' NA with a turbo engine in it and they didnt change the ECU and wiring harness so they have a box of turbo stuff, that incudes turbo, headers, and a bunch of misc parts, for $200. Even if anyone hasnt put a turbo on a NA, is a box of misc Supra turbo stuff worth it for $200? Thanks!
supraman121 08-04-2007 08:52 PM
Ya its been done its call an NA-T but there is a little more to it then just adding the turbo, you need the intercooler the hardpips, exhaust manifold, new turbo headers i think ecu, blow valve, and with the Non turbo head gasket you could blow it, so youll have to replace that and you cant boost very much with the stock 7m engine iv seen poeple say they boosted there to 9.5 psi that isnt that far from the stock 7mgte boost lvl, I think you would be better off to get a shot of nitrous instead do like a 25 or a 50 shot.
Chambers 08-04-2007 10:10 PM
Well I know of all what is needed, I've done a lot of research on this subject, and not just with Supra turbo apps, but I guess a better question would be could the NA ECU adapt to a very slight turbo app.? Thanks for the imput though! Also I have a metal HG on it and its a JDM, so the only thing I could think of is some forged pistons and rods, and sturdier head bolts.
Well thats it, I plan to do both.
j3pz 08-05-2007 01:52 AM
if you turbo a n/a you will need the turbo ecu or your car will run like pooh. or could get a a/f controller
also many people boost on 7m's (upgradedsupra's sig = BOOST ONLY! 814.62 RWHP@32psi 690 RWTQ )
Chambers 08-05-2007 02:10 AM
Yea I knew that it wouldnt run too great strait up, but I was wondering if anyone had done it before with no turbo ECU, and low boost. I'm going to try it anyway and see what happens. If I did get a A/F controller what engine would I get it for, turbo or NA? Thanks.
supraman121 08-05-2007 03:57 AM
Well, I dont know if he would have to get a new ecu i would think the old one would work... they turbo charge civics and they have to use the original ecu, if you can program the original ecu it should work.
j3pz 08-05-2007 02:00 PM
the turboed civics ecu depends if they did a swap or kept the d16. if they did a b-series swap they need a b-series ecu, a k-series swap they need a k-series ecu.
the fuel maps are different for the supra n/a and supra turbo. so at a specific rpm the cars recieve a different amount of fuel. THE NA ECU WONT WORK FOR THE TURBO WITHOUT A A/F CONTROLLER. if you wanna go blow up your fresh conversion go ahead... you will run lean like a bitsh and motor go boom
as for the a/f controller, get the turbo one, it will be a turboed car right???
ninja edit 2: if you dont wanna listen to me, just go to a local shop and ask them
