Old 08-06-2007, 05:17 PM   #1
oowee623
oowee623's Avatar
oowee623 is on a distinguished road
Default losing brake fluid
since i removed my master cylinder ive been losing brake fluid, the brakes are way too sensitive, it locked up on me at least 3 times, and the pedal is spongy, it goes to the floor every time and i can hear a hissing noise like air is escaping from the booster. will this all go away after bleeding it or is it more serious like a faulty master cylinder or worn seals? it doesnt feel as safe as it used to be, btw i dont have abs
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
oowee623 is offline   Reply With Quote
Old 08-07-2007, 04:42 AM   #2
mrnickleye
mrnickleye's Avatar
Angry
Do NOT pass go. Never touch your brakes if you don't know how to repair them properly.
Go directly to a qualified shop and have them repaired.
STOP ! Playing with your (and others on the road) life.
Old 08-07-2007, 07:36 AM   #3
oowee623
oowee623's Avatar
i realize that, but any suggestions on what it is exactly, i feel that you are underestimating my knowlege and expertise becasuse of my age, im only 17 and everything i can do myself ill do it something i cant do ill have a mechanic do, im tight on budget and therefore my labor is cheaper.
Old 08-07-2007, 04:44 PM   #4
plaaya69
plaaya69's Avatar
plaaya69 is on a distinguished road
It sounds like a bad master cylinder. The seals are probably bad.
If you need one though, I have one from my 87 Turbo that looks line new(with no rust) and works great.
1987 Toyota Supra Turbo-burgundy exterior w/gray interior+1987 Toyota Supra(N/A) light brown top,dark brown bottom w/light brown interior.
plaaya69 is offline   Reply With Quote
Brake Fluid Dot 3 or 5.1 colin172 MKIII Supra 6 10-17-2007 10:44 PM
Brake Fluid Reservoir igosaur MKIII Supra 2 06-28-2007 10:55 AM
Maintenance brake and clutch master cylinder fluid IHateHacks MKIII Supra 1 04-18-2007 07:15 PM
Wilwood MKIII Rear brake kit ARZ Arizona Performance 0 03-16-2007 07:46 AM
losing clutch fluid Supra2NR Non-Generation Specific Questions 3 05-16-2006 10:08 AM
