Old 05-28-2005, 12:27 AM   #1
Supradrew
Supradrew is on a distinguished road
I have a 91 supra and it has the non-turbo (duh) i have had a miss in one of the cylinders. we put all new tune up parts on it and replaced the radiator and the thermostat and the belts. well, it's no longer overheating, but it still has the miss. #4 cylinder as best we can tell. also, we couldn't get the rotor off? No smoke, compresion test says it's ok, but has a consistant miss? any thoughts would be helpfull...
Supradrew is offline   Reply With Quote
Old 05-28-2005, 03:03 AM   #2
KingDiamond
KingDiamond is on a distinguished road
What octane gasoline are you running. If your only running 87 octane, you may have a piece of carbon on that cylinder that is preigniting the gasoline and then when the spark plug fires and ignites the unburned fuel or exhaust the two flame fronts will collide causing a ping or knock. Possibly acting as a mis in the one cylinder you are talking about.
KingDiamond is offline   Reply With Quote
Old 05-28-2005, 03:05 AM   #3
KingDiamond
In other words if your only running 87 octane, try running a higher octane like 89 or 93. Also what kind of spark plugs did you use as replacements. What Brand, what are they produced out of, platinum, etc..
Old 06-01-2005, 05:51 PM   #4
Supradrew
It's been properly diagnosed. #4 injector was broken. Bosch replacement $82.00. Phew ~ Thx for your thoughts.
Old 06-01-2005, 06:17 PM   #5
KingDiamond
glad you found the problem, and it turned out to be relatively inexpensive problem.
