Old 08-08-2007, 05:52 AM   #1
87supran/a
87supran/a is on a distinguished road
Default headlights
i ham having problems keeping my headlight centered on the road, it seems that when i turn them off and they go back down, they get reset and go back to the place where they were originally set, i have tried to adjust with the knob but no luck. One side is also brighter than the other, andy ideas on how to fix it. I am not sure where the gounds are, i have looked throught the electrical guide that someone gave me but it sadly was no help..
suggestions
87supran/a is offline   Reply With Quote
Old 08-08-2007, 06:28 PM   #2
For the dim lighting issue I generally recommend people just rewire the headlights to run off the alternator. Here's a goos writeup and info: http://www.danielsternlighting.com/t...ys/relays.html
As for the headlights moving, make sure everything is firm and stays in it's place. There are a lot of screws and bolts in the assembly and even the smallest amount of play can cause the projected light to move a lot.
Headlights not working SilenceboneSupra MKIII Supra 1 01-08-2009 10:08 PM
Headlights going bonkers! RNEMESiS42 MKIII Supra 3 12-17-2007 08:39 PM
Projection Stly Headlights? critterCQB MKIII Supra 6 10-17-2006 04:27 PM
