Old 08-09-2007, 06:30 PM   #1
godgaveussid
godgaveussid's Avatar
godgaveussid is on a distinguished road
Default Does the "oil on the top of uour spark plugs" sticky apply to me?
does this apply to oil on the spark plug tip? the other day my ghetto rigged ic piping popped off. car ran super rich for about 20 feet until i could get to a gas station. after that, car was hesitating under load, thought it was knock so retarded the timing alot...no help. by proccess of elimination, must be a fouled plug right? went and dropped $70 on denso iridium plags and but them in. when i took the old shitty autolites out, plug #6's tip was covered in oil. it was kinda hard to tell where on the plug the oil was since my buddy kinda smeared it with his fingers. first time under load after denso install...same hesitiation. now, i dont have the spark plug socket with me right now but im pretty sure when i pop #6 off tomorrow, it will have oil on it. does this sticky apply???? thanks.
1992 BMW 325is - custom turbo kit, tial 38mm, 1g dsm bov, t3/t4, 18's and new paint...dead.
1981 Datsun 280zxt - bought, broke, sold for profit.
1993 Camaro Z28 - lt4 heads, hotcam, full bolt-ons , 430rwhp 450 rwtq, traded for...
1991 Supra - 30k on new jdm 7mgte; 60k on n/a chasis. intake, hks mhg, mbc, 3" custom turboback, crossdrilled rotors, sunroof.
COMING SOON: hard pipes, greddy profec b, hks turbo timer, lexus afm, 550's, mkiv fuel pump, blitz bov.
godgaveussid is offline   Reply With Quote
Old 08-09-2007, 06:48 PM   #2
supradaddy0803
supradaddy0803's Avatar
Does your car after sitting over night smoke a bit when you crank it up? The sticky is about the little metal plate over the top of the spark plug valley leaking and how to fix it. If the part of the plug that goes into the cylinder is covered in oil means you are burning oil because of blowby or bad valve seals. If the oil is on the other end of the plug where the wire goes on then you need to heed the sticky and fix it because it sucks getting all of that oil out.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 08-10-2007, 12:04 AM   #3
godgaveussid
yeah im thinking it might be a valve or guide...maybe even a seal.
bummer.
