Old 08-08-2007, 01:38 PM   #1
novaguy009
novaguy009 is on a distinguished road
Default New Head Unit Won't Work
I installed a head unit yesterday. Used the online wiring guide and hooked up the unit. The previous owner said something about plugging the antenna in to get the security system to work.... I need an antenna adapter.
Either way, I can't get the head unit to turn on. Is there a reset or something I don't know about? Where's the fuse? I found the panel under the hood, but I'm guessing there's another fuse box hidden inside somewhere. There's two wires under the console that look like plug in antenna wires. There's a small one and a big one, what does each do?
Any ideas?
Kev
novaguy009 is offline   Reply With Quote
Old 08-08-2007, 06:32 PM   #2
Both antenna wires are just what they appear... antenna wires. The smaller one is for an antenna that's laminated to the rear windshield. The larger one is for the powered antenna.
Check the Radio and Dome fuses. Here's the wiring diagram for the stock radio:
http://www.cygnusx1.net/Supra/Librar...x?S=Main&P=134
And here's the diagram for the stock stereo w/CD player and amp:
http://www.cygnusx1.net/Supra/Librar...x?S=Main&P=132
If you're car has the amp you may need to remove that to get everything working properly, but I'm pretty sure the new head unit should still power up.
Old 08-10-2007, 06:18 PM   #3
novaguy009
I got it. The red switch 12V wire in my radio plug was not hot when switched. I tapped into one of the other plugs with a hot 12V and now we're powered up and ready to rock
Kev
N20 and HeAd WoRk Supra_87_mk3 Non-Generation Specific Questions 4 05-25-2007 03:09 PM
head lights dont work. 4runninghank Non-Generation Specific Questions 0 12-18-2006 04:00 AM
twin turbo 96 head work bennyboy55 MKIV FAQ 5 10-26-2006 01:30 AM
Head Gasket work G-string MKIII Supra 5 04-20-2006 11:23 AM
Can someone help a noob trying to wire up his head unit ogkush Car Audio and Alarms 1 02-19-2006 09:53 AM
