Old 08-11-2007, 02:05 AM   #1
sbnryn15
sbnryn15 is on a distinguished road
Default 2jz in a mk3
i have a 87 n/a supra 5 speed, and i also have a 2jz with an auto trans. i was just woundering what all i need to complete this swap
p.s the engine also came with a stand alone and uncut harness.
sbnryn15 is offline   Reply With Quote
Old 08-11-2007, 06:26 AM   #2
supraman121
Did you get the turbos and the intercooler and hardpipes? if you got a complete engine you should be good seeing how you have the uncut harness and the stand alone i think... But your going to need custom mounts fot the engine and the trans i think. I really dont no much about the 2jz but i think that is all you need dont quote me tho
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 08-11-2007, 12:09 PM   #3
sbnryn15
yeah i have everthing and also can i use a my 5 speed n/a trans or no
Old 08-11-2007, 03:06 PM   #4
OfnaRcR
OfnaRcR is on a distinguished road
Search these forums of supramania.com 's forums
OfnaRcR is offline   Reply With Quote
Old 08-11-2007, 08:02 PM   #5
supraman121
I think you can if you use the 2jz bellhousing it should work, wont be able to handle as much power as the 1jz or the 2jz transmission.
K&N Air Filter
Old 08-11-2007, 08:15 PM   #6
sbnryn15
i mean i'm only 16 so a 2jz should be fine for the time being
