Old 08-13-2007, 08:40 PM   #1
87supran/a
87supran/a is on a distinguished road
Default speedometer cable replacement
anyone have an idea on how to replace the speedometer cable, i broke it when i was putting my dash back on? Thanks
87supran/a is offline   Reply With Quote
Old 08-13-2007, 09:51 PM   #2
supradaddy0803
supradaddy0803's Avatar
Well some of it is really hard to get to but it isnt hard to do. On the firewall inside the hood you will see where it exits on the other side under the dash there is a bolt holding a seal bushing around it when you remove the bolt you can remove the seal. Also there is a bunch of holding clamps that support it as it goes under the car. It is pretty easy if you look in the TSRM it will show the process. I had the same problem when I thought I damaged mine but sometimes if you try you can take the driver out of the end of the cable and try to fix it I did and it worked. It is always worth a try.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 08-13-2007, 09:54 PM   #3
87supran/a
i will have to look into it, but wat exactly is the TSRM
Old 08-13-2007, 09:56 PM   #4
f00g00
What did you actually break? Got a pic?
Old 08-14-2007, 12:13 PM   #5
fulljapan
fulljapan is on a distinguished road
Toyota servire repair manual.. look around the forum you will find the link cause I'm at work and I don't have it close :P or someone will probably give it to you on this thread
fulljapan is offline   Reply With Quote
Old 08-19-2007, 04:49 PM   #6
87supran/a
it was the needle itself that goes into the speedometer that broke. Also the gauge (when it was working) was also "bouncing" around, it never gave me a striaght speed, could that mean a bad connection somewhere?
Old 08-19-2007, 08:18 PM   #7
f00g00
A broken cable end means cable replacement. You will have to replace the cable from the firewall hole down to the small cable that comes from the transmission. There is a rubber grommet that attatches where the cable goes through the firewall to protect the cable and keep odors from the engine bay from entering through the hole. You will probably have to take off the panel under the steering wheel and snake your hand up there to route the cable to the back of the gauge cluster. Take a look at the current routing before you rip out the old one.
The cable runs behind the block and down through a couple of clamps attatched to the body then runs over the exhaust to the small cable. If you have headers like me you will want to wrap something like heat tape over the cable or it might melt like mine did. The melting cable cost me a couple of hundred in repairs and parts.
The bouncing needle could mean the plastic output gear is getting worn and is slipping. Also check the crimps around the cables where they meet by the exhaust. If the crimps are going bad the center cable could be binding against the outer shielding and that could ruin the plastic gear. My plastic gear went when my cable froze. It froze the plastic gear which lost the battle with the inner metallic drive gear.
Old 04-01-2009, 07:28 PM   #8
gottysupra88
gottysupra88 is on a distinguished road
how does the plastic part that connects to the speedometer come off?
gottysupra88 is offline   Reply With Quote
Extra Cable? 808Supra MKIII Supra 1 08-17-2006 08:15 AM
