Old 12-07-2013, 10:29 PM   #11
LockedOut
LockedOut is on a distinguished road
Fixed.
This confirms authenticity of electric lockout / valet mode / whatever you call it. 100% real.
Crawled back there.
Removed rear cover via 7 screws.
Easily saw how to pop latch w cable.
Upon removing cover, looked for wire that aligned with key lock, disconnected that wire via simple harness clip.
Lock easily turned.
Test manual latch without electric clip connected. Locked and unclocked via key without a problem.
FYI,
Used very small and thin ice pick / knife to get covers off of screws. Used only a phillips BIT, not an entire screw driver, to unscrew the 7 screws, to avoid space issues with the underside of the hatch.
Keywords...
lockout
antitheft anti theft deterrent
hatch
rear hatch lock locked
LockedOut is offline   Reply With Quote
Old 12-08-2013, 02:24 AM   #12
Green7mgte
Supra Forum Moderator
Gonna link this post also
http://www.toyota-supra.info/forums/...questions.html
oh the trunk woes.. been there.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Rear Hatch Won't Open-HELP! Benesesso MKIII Supra 4 07-21-2008 12:37 PM
rust rear hatch l&r lower window corners hayduke Non-Generation Specific Questions 0 12-17-2007 06:24 PM
Styrofoam Inserts in Rear Hatch bpalmer21 MKIV Supra 0 08-01-2006 04:48 PM
Rear Hatch Cover, retractable scorpmatt MKII Supra 4 01-30-2006 05:12 AM
