Old 05-30-2005, 02:30 PM   #1
steel
steel's Avatar
steel is on a distinguished road
looking to get red of my emmissions looking for a step by step and a stand alone ecu recomendation
thank you
stick flick VOL1
stick flick VOL2 nazz tank
B.O.T.H.
2002 nissan sentra GXE
1998 nissan sentra GXE(bondo bomber)
1989 toyota supra 7mGTE
2004 yamaha rapter
steel is offline   Reply With Quote
Old 05-30-2005, 09:33 PM   #2
monkihead
SP58GT
monkihead's Avatar
AEM makes the easiest stand alone i've seen yet, which is a plug n' play. so far as emissions, what are you trying to take off??
monique- better off dead
Old 05-31-2005, 03:25 AM   #3
steel
steel's Avatar
yes...loss the erg mostly and stop the reuse of exhuast gas in to the intake
stick flick VOL1
B.O.T.H.
2004 yamaha rapter
Old 05-31-2005, 04:14 AM   #4
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
i'm not sure of removal of egr as we don't have it here... but we do have stock egr block off plates, one bolts to the back of the intake manifold and the other bolts on to the back of the head on exhaust side
i'll see if i can find a write up somewhere for ya
Pics of my build.
Do a diagnostic first!
Old 05-31-2005, 04:34 AM   #5
suprra_girl
7M POWAH! ;)
here's some tips from users from sf
mikkee123:
its possible. Takes time and patience. There are two 12mm nuts underneath the actual egr valve. You need an extension and the 12mm socket i think. With time and patience it will take you 30 min max. Also..you need to block off the egr vacuum line. It comes off of the throttle body, down under the intake manifold, to a vsv and then to the egr modulator. Cap off that line, and the 2 egr ports and you're set. Pretty straight forward
conundrum07:
You need the block off on the upper intake manifold. The other one on the lower manifold is not needed if you block off the EGR cooler on the back of the head (this way is better, keeps the heat away from the back of the head).
drjonez:
for blocking vacuum lines
-the one on the TB, just cap it.
-the one that comes off the metal vac tubing under the intake manifold (feeds the VSV under the intake manifold), just cap it.
dunno if you can view this
http://www.supraforums.com/forum/attachmen...tid=32713&stc=1
that's all i can seem to find for now
Pics of my build.
Old 06-01-2005, 01:54 AM   #6
steel
steel's Avatar
you rule..........were are you from
stick flick VOL1
B.O.T.H.
2004 yamaha rapter
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
Nissan Sentra Tranny problem. redmaro Off Topic Forum 2 11-28-2006 01:58 PM
found the problem brs86supra MKIII Supra 0 05-02-2006 03:42 PM
tsp problem for na t supra jdlee123 MKIV Supra 0 09-02-2005 06:01 PM
