Old 08-20-2007, 03:56 AM   #1
supraman121
Default Twin turbo on 7mgte?
Would you be able to do a twin turbo setup on a 7mgte, is the 1jz ecu compatable with the orginal 7mgte ecu plugs/plugins, and does the 1jz manifold work on the 7mgte engine?
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
7MGTE Twin Turbo Maniforld? suav MKIII Supra 5 04-20-2007 04:46 AM
7mgte Twin Turbo? 86.5NA MKIII Supra 2 11-13-2005 11:41 PM
twin turbo manifold on 7mgte boner1115 MKIII Supra 9 11-07-2005 02:27 AM
