Old 08-26-2007, 05:59 AM   #1
supraman121
Default How would i go about doing this?
How would i get oil to a turbo on an n/a 7mge engine i know were to put the return line.
Plz dont tell me why dont you just upgrade to a 7mgte engine cause it would just be cheaper to buy another turbo car instead of upgrading to the turbo engine, i would just like stock boost on my current engine.
Do you think this would work or one of these i know it says for gauges but could it possiably work?
http://www.optionimports.com/oilfiblad.html
Sorry if it sound rude,
Thanks in advance.
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 08-26-2007, 04:15 PM   #2
Chambers
Chambers's Avatar
There is a threaded hole in the block of the turbo engine that isnt there on the NA, at least its not on my block, I just looked at it because I plan to do a NA-T conversion to my engine as well, so you might have to make a custom fitting or just modify the existing one to another spot for oil, as for the oil filter adapter, it might work but there might not be enough oil running through that for a turbo if its for guages, but I could be wrong. Good luck!
Old 08-26-2007, 05:05 PM   #3
mrnickleye
mrnickleye's Avatar
Default can work
You could easily use one of those oil filter adaptors. Also run in-line an oil cooler (mount out front of the ac condensor).
Here's a good one.
http://store.summitracing.com/partde...5&autoview=sku
Old 08-26-2007, 06:47 PM   #4
supraman121
Thanks i forgot about the oil cooler i was think of an oil catch can but i didnt know if it would work or not lol
K&N Air Filter
