Old 08-26-2007, 10:05 PM   #1
Boombastic
Boombastic is on a distinguished road
Default Ignition
Hi, my 88 supra takes abnormally long to start when it is cold. Is it because of the fuel pump or am I just getting a weak spark? Also when the engine starts to start it studders then finally gets going. Anyone know any tips or had this happen to them? Thanks.
Boombastic is offline   Reply With Quote
Old 08-27-2007, 01:57 AM   #2
f00g00
Check your cold start injector, make sure the plug is connected.
or
Cold Start Injector Time Switch might be out of specs, again check the connection.
FI-77 and FI-112 show you how to check them.
http://www.turboninjas.com/mk3supra/...-EFISystem.pdf
Those are the two easiest things to check for a cold start problem.
Old 08-27-2007, 04:22 AM   #3
I don't think its your problem, but read this to eliminate it as a possible.
http://www.toyota-supra.info/forums/...ead.php?t=4657
note...
Also, the switch is heat/cold controlled. If the temp outside is more than about 65* (maybe 55*) it won't allow the injector to come on, to prevent flooding. Also, even in a snow storm, after 12 seconds of cranking time, the switch will stop supplying current to the injector. (prevent flooding)
Ignition Synchronizer - what is it ??? cgreiner MKIII Supra 4 01-15-2009 08:39 PM
MSD ignition system for MKIII? Boombastic MKIII Supra 1 08-21-2007 03:21 PM
Ignition Ghost motosparky MKIII Supra 3 11-15-2006 03:45 PM
Ignition dcrusupra MKIII Supra 5 10-04-2005 09:09 PM
