-   -   Ignition (http://www.toyota-supra.info/forums/mkiii-supra/9457-ignition.html)
Boombastic 08-26-2007 10:05 PM
Ignition
Hi, my 88 supra takes abnormally long to start when it is cold. Is it because of the fuel pump or am I just getting a weak spark? Also when the engine starts to start it studders then finally gets going. Anyone know any tips or had this happen to them? Thanks.
f00g00 08-27-2007 01:57 AM
Check your cold start injector, make sure the plug is connected.
or
Cold Start Injector Time Switch might be out of specs, again check the connection.
FI-77 and FI-112 show you how to check them.
http://www.turboninjas.com/mk3supra/...-EFISystem.pdf
Those are the two easiest things to check for a cold start problem.
mrnickleye 08-27-2007 04:22 AM
I don't think its your problem, but read this to eliminate it as a possible.
http://www.toyota-supra.info/forums/...ead.php?t=4657
note...
Also, the switch is heat/cold controlled. If the temp outside is more than about 65* (maybe 55*) it won't allow the injector to come on, to prevent flooding. Also, even in a snow storm, after 12 seconds of cranking time, the switch will stop supplying current to the injector. (prevent flooding)
