Old 08-27-2007, 11:08 PM   #1
justin1642
justin1642's Avatar
justin1642 is on a distinguished road
Default air fuel ratio guage
ok i lost the directions on how to hook it up but i have the power going to the battery and i have it grounded and i have the blue wire inside the o2 sensor plug and now the guage won't turn off. i had it this way before and it was normal but now since i spliced a new plug on it hasn't turned off.
so my question is did i do it right or what did i do wrong?
justin1642 is offline   Reply With Quote
Old 08-28-2007, 05:44 PM   #2
Supra2NR
Supra2NR's Avatar
hook it up not to the battery but to the, lights with the ignition so it only turns on when you turn the key on
supra head gasket questions+ rebuild Andy C MKIII Supra 169 05-18-2010 01:59 AM
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
fuel pressure guage FullOfProblemsMKIII MKIII Supra 3 01-21-2008 11:52 PM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
whats up with my fuel guage? okinawa 92 MKIII Supra 2 05-10-2006 11:22 PM
