Old 08-29-2007, 05:56 PM   #1
twerb089
twerb089's Avatar
twerb089 is on a distinguished road
Unhappy engine harness trouble
so a while back i bought a engine wiring harness from mizubo and it doesn't fit. i was told that the harness was from a 89 turbo auto but apparently its not. the problem is that it will not reach to the 6th injector. therefore the connectors for the starter and trans will not reach. im kinda lost on what to do, any help guys?
oh and i've pm'd the guy but he wont respond
1989 supra turbo automatic soon to become a manual
K&N, megan dp, gutted cat, 2 1/2" magnaflow cat back
NA intake cam, shimmed actuator
no A/C or P/S, therefore no ac condensor, compressor and no ps pump or resivior.
gutted interior, 4 tweeters, 2 kicker 12"s powered by an MTX 400W 350rms and an audiobahn 400W 300rms
twerb089 is offline   Reply With Quote
Old 08-30-2007, 12:45 AM   #2
supraman121
Have you seen how much it would cost to get that part of the harness extended, spliced or anything like that? use part of the old one with the new one? Dont no if that will help but you could look into it.
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 08-30-2007, 04:41 PM   #3
twerb089
twerb089's Avatar
thats what ima try to dy myself. is solder some extensions on. but this is BS, shouldn't all the wiring harnesses be the same length?
Old 08-30-2007, 05:03 PM   #4
j3pz
what do you mean it wont reach the sixth injector? the clip wont reach or the harness wont reach? is it by a couple inches or a like 2-3 feet? only asking cause im wondering if you got a rhd harness. either way, you can just extend it. just get some stranded 12 or 14 awg wire and some red butt connectors and electrical tape. when i damaged my harness, thats all i did and it worked fine, cant even tell where i spliced it
Old 08-30-2007, 06:29 PM   #5
twerb089
twerb089's Avatar
the harness wont reach by like a foot.. but when i test fitted it everything else looked like it would be able to make the stretch.. i hope it does
engine rewiring trouble mizuboi MKIII Supra 0 01-09-2008 08:33 AM
7mge engine harness 77celi MKIII Supra 19 07-15-2007 07:51 PM
Engine Harness question kidsusukigsxr Non-Generation Specific Questions 0 01-31-2007 05:33 AM
