Old 09-02-2007, 05:56 PM   #1
EpilepticPuppy
EpilepticPuppy is on a distinguished road
Angry I give up...
I did a rebuild because I thought I had a bhg....while the head was off it was machined and milled at a engine shop. Put the thing back together, timing was done by a mechanic, and I have cleared out all the errors.
The problem is that when it starts it dies right away unless I give it gas. Then it won't stay started unless I keep it above 2k rpms. Is there anyway I could have put something back together wrong to make this anomaly not stay idle but still run at higher rpm?
I have changed the fuel filter. There is fuel pressure because I cracked open a bolt to see if it was torqued right, and it was.
I checked the vacuum hoses and they are all routed correctly.
I have tried kicking the tires.
I have tried talking nice to it.
But nothing seems to be helping.....Anyone have any suggestions before I take it to the dealer and give them a bag of money? If anyone guesses the problem correctly I will buy them a steak dinner, no joke.
It's an 89 NA supra exterior white with blue interior if that helps.
EpilepticPuppy is offline   Reply With Quote
Old 09-02-2007, 06:33 PM   #2
Chambers
Chambers's Avatar
Theres a idle control screw in/on the throttle body, check that to see if its there. Its on the opposite side of the oil breather lines facing the front of the car.
Old 09-02-2007, 10:34 PM   #3
supramacist
supramacist's Avatar
Right off I'm thinking fuel pump.
Fuel filter.
Old 09-03-2007, 01:11 AM   #4
Supra2NR
Supra2NR's Avatar
Fuel filter.
if the fuel pump is screwed, wouldnt it not start at all?
Old 09-03-2007, 12:38 PM   #5
supramacist
I thought about that after i posted and then thought fuel filter.
Yes. It wouldn't fire up if you weren't getting any gas.
My 91 has 2 filters.
One is in the tank and the other is under the body up under the rear seats.
Old 09-03-2007, 05:28 PM   #6
I had a similair problem, my motor would sputter when started up and would die unless I kept it above 1700 RPMs... Check to make sure your vacuum lines aren't cracked and are routed correctly. I had two go to the wrong place, switched them around, and now she purrs at a good 700 RPMs, nice and strong.
Old 09-04-2007, 12:21 AM   #7
supradaddy0803
supradaddy0803's Avatar
Make sure that when you put the intake manifold back together you didnt get a bracket or something stuck between them because it causes a nasty vaccum leak. When you get it running like you said have someone give it gas and look to see if your exhaust manifold is glowing red that is a dead give away that it has a vaccum leak somewhere and it is running lean.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 09-04-2007, 01:28 AM   #8
carfanatic89
carfanatic89's Avatar
This happend to me, When i put on the exgaust manifold i didnt put the heat shield on and it melted the intake tube and put a hole in it. I didnt think about the small things. When i melted the tube, I threw about 100 buck at the car in parts and all it was, was a hole in the Intake tube. It could also be the TPS or the Massairflow sensor, make sure these are pluged in there easy to miss.
Old 09-04-2007, 04:56 AM   #9
wyosupra
wyosupra is on a distinguished road
I had an Isuzu Imark that would only run if I was on the gas and it was the fuel pump.
1990 Targa Turbo apexi 3" MHG
FOR SALE!! 1988 Supra Targa Top Turbo
3" Magnaflow
wyosupra is offline   Reply With Quote
Old 09-06-2007, 06:21 AM   #10
I'm sorry I didn't see this sooner. The first thing I would check is the FC switch in the N/A AFM. Turbo models don't have this and it's usually not suggested, but I've seen them fail for a few people (unfortunately, usually after they'd spent a bunch of money on other things).
http://www.cygnusx1.net/Supra/Librar...aspx?S=FI&P=95
A couple other possibilities are timing (yup, still a possibility) physical or ignition, TPS IDL switch, fuel pump, fuel pump relay and/or resistor pack, clogged ISC or dead stepper motor in the ISC, bad alternator (try charging the battery and see if the car will idle at least for a while with a full battery), and lastly, a bad ignitor.
DOes this sound like a good Deal plz give advice Jbone7 Non-Generation Specific Questions 0 03-06-2008 03:21 AM
What turbo would give me the most power at 6-8psi supraman121 MKIII Supra 9 09-11-2007 12:45 AM
head gasket gone would it give oil in turbo intake johnkarl MKIII Supra 7 10-31-2006 06:38 PM
Can some of you guys give me some info on these cars? Big Jimbo MKIII Supra 5 01-07-2006 08:24 PM
give me money .. NOWWW TRAFIK Non-Generation Specific Questions 0 11-06-2005 06:12 AM
