Too Heavy?
I am putting a new HG on my supra and looked in my turbo and a few fins on the turbine are chipped, Is this too big of an upgrade too heavy for the shaft?
The turbo has no shaft play and spins easy. http://cgi.ebay.com/ebaymotors/WOW-T...spagenameZWDVW |
Also will i need an fpr and a wideband to tune this upgrade i have the wideband already.
maybe a walbro?
Anybody have any suggestions on an upgrade?
Personally, I wouldn't run it if it were given to me. 60-1's are nice enough, whiile they last. The biggest *reliable* upgrade is probably the 57 trim that a couple shops offer. If you're looking for higher volume than that's capable of it's time to start looking for a turbo that built for it.
Is this the best place to get an upgrade? I was looking a little cheaper. Will the stock fuel pump regulator and injectors handle the 60-1? Or at least the 57?
http://suprastore.com/ct26turup.html Thanks |
