Old 09-12-2007, 05:08 AM   #11
88Tsupra
88Tsupra is on a distinguished road
well I use vacuum plugs on the two hoses and a plug on the vacuum line itself and it ran but sounded like compressor surge but then again there is the video of an STI with a Tial BOV
im using a 7psi spring is that to low
http://www.youtube.com/watch?v=tXqgTtHECnk
88turbo targa-white
original Pin Stripe
custom intake-Tenzo filter.....Momo racing seats and steering wheel...
apexi exhaust tip-custom 3" piping. Replaced with RSR GT II
NGK plug and wires
HID conversion head lights
HKS Turbo Timer Type-1 (in black)
Tial BOV
BIC DDP
88Tsupra is offline   Reply With Quote
Old 09-12-2007, 05:12 AM   #12
oowee623
oowee623's Avatar
oowee623 is on a distinguished road
so you got it to work?
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
oowee623 is offline   Reply With Quote
Old 09-12-2007, 05:33 AM   #13
west_side_supra
west_side_supra's Avatar
i dont know if those are adjustable or not, if it is loosen it up, if that doesnt work go to your auto store and pick up some white lithium grease and spray it inside the BOV and push the valve up and down, make sure its not sticking, cause i know my ssqv never worked untill i sprayed some lithium in there. so id recommend giveing that a try. other than that make sure you are useing a good vacume line.
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 09-13-2007, 05:31 AM   #14
88Tsupra
no andrew its not working i think...
I'll try anything right now so I'll probably buy some lithium white grease tomorrow at autozone and try it at auto class.
I use the same vacuum line that goes to the stock BOV and im using silicone hose
edit: the TIal is non adjustable
88turbo targa-white
original Pin Stripe
NGK plug and wires
Tial BOV
BIC DDP
installing thermostat sd88supra MKIII Supra 8 06-18-2010 02:23 AM
installing gauges firewall ClutchR1 MKIII Supra 3 11-11-2008 01:05 AM
Tial 50mm BOV vs HKS SSQV BOV 88Tsupra MKIII Supra 5 08-29-2007 11:31 PM
question about installing a JDM mad_dicer MKIII Supra 7 11-12-2006 03:21 PM
