Old 09-11-2007, 01:32 AM   #1
west_side_supra
west_side_supra's Avatar
Default what you guys think?
ok so it just started to do this yesterday, it sounds like its missfireing or someone put some aftermarket cams in the car over night
weird idle
we checked the plugs - no problems
checked the injectors - when unplugging cylinder 4 injector clip, no difference in sound while all the others made the idle go down plugged it back in gave it some gas and WOO HOO white smoke out the ass, unplugged it again and pluged it back in no more smoke? whaa? it was sweet smelling and seriously looked like a BHG. and i wouldnt doubt it is since the car likes to over heat. i let the pressure out of the radiator while it was running the car started to idle fine.
i have to say though it sounds pretty bad ass in the morning when its cold, BLUB BLUB BLUB RRRRRRRRRAAAAARRRRRR
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 09-11-2007, 05:08 AM   #2
supramacist
supramacist's Avatar
Run some injector cleaner or a qt of atf in your next fill up and run high octane.
Sounds like you just have some carbon build up.
We should always beware of a lurking BHG.
Old 09-11-2007, 06:48 AM   #3
abhattan
abhattan's Avatar
abhattan is on a distinguished road
that #4 cylinder seems to be a dead cylinder. check for spark then fuel. or after you run it, take the plug out and crank it, if any water comes flying out, you got a blown head gasket!
'91 Turbo Targa 5 Spd.
'87 Corolla GT-S 5 Spd
'91 Accord Daily Driver 5 Spd
Soon to be rebuilt (All to some extent)
abhattan is offline   Reply With Quote
Old 09-11-2007, 09:06 AM   #4
west_side_supra
ok now let me ask you this, 2jz swap or fully rebuilt 7mgte with top of the line internals?
fidenza cam gears
Old 09-11-2007, 02:25 PM   #5
86SupraMan
86SupraMan's Avatar
86SupraMan is on a distinguished road
another thing you could try instead of running high octane, is run med octane then buy a bottle of octane booster for like 5-10$, would save you some gas and get the same result.
as for the swap. id say 7m with best internals. thats what im plannin on doin with this junky engine i have, if u do the 7m rebuilt with studs and best internals possible, u can run a decent amount of boost, pretty much, those internals will probably make ur 7m better than the 2j. in any case, your supra would probably scream after a swap like that ;P
86.5 Toyota Supra
((Current Mods)) :
-Slotted/Crossdrilled Rotors
-K&N Filtercharger
-H4 Projection light Conversion
-Magnaflow Catback Exhaust
-=Mods to do=- :
-Rust Repair
-Bodykit
-Paintjob
-Engine work
-Suspension
-Wheels
-Intake (Semi-Done)
-Exhaust
86SupraMan is offline   Reply With Quote
Old 09-11-2007, 10:28 PM   #6
west_side_supra
so what you know bout this
parts ordered so far
JE pistons 8.4:1 compression .020 bore
egale rods
Greddy timing belt + tensioner
HKS MHG w/stopper
ARP head studs
ARP Main studs
full engine gasket set
all bottem end bearings
water pump
oil pump
fuel pump
valve cover studs
hose techniques silicone hose kit
RC 750cc injectors
lexus MAF
FCD
greddy upgrade turbo
FIDANZA ALUMINUM FLYWHEEL
oh cant forget the TRD OIL FILTER WHA WHA TRD ALL THE WAY!!
there is more i just cant think off the top of my head everything, the head will be getting parts ordered next week maby so.
in the process of the block being tested, surfaced, and bored
still in process of dissasembling the head for surfacing and P&P
ill be getting pics of the rebuild as i go along so ill try to keep everyone posted.
fidenza cam gears
Old 09-11-2007, 11:22 PM   #7
abhattan
abhattan's Avatar
If it is done right, you could run at least 30psi. With the right turbo and fuel and tune, 700hp easy.
Old 09-11-2007, 11:53 PM   #8
west_side_supra
my dreams come true
i've always wanted 700hp, but i dont think 30psi is going to be to safe with me maby 20-25, but with all those parts plus some over sized valves what would you say i would be pushing? i was looking at possibly doing the cams to
fidenza cam gears
Buying supra need advice guys sisqojazz Non-Generation Specific Questions 1 03-21-2007 10:47 PM
I need you guys opinion on this 1994 Supra Jiwon Non-Generation Specific Questions 2 06-14-2006 01:58 AM
Hey guys, should I purchase this? ravE MKIII Supra 1 03-18-2006 08:09 AM
Can some of you guys give me some info on these cars? Big Jimbo MKIII Supra 5 01-07-2006 08:24 PM
Sup Guys..!!!! Ruben Non-Generation Specific Questions 29 07-06-2005 09:38 PM
