Old 09-11-2007, 09:42 PM   #1
tip kindel
tip kindel is on a distinguished road
Default Block off hose
I have an 86.5 Supra, non turbo, and can find nothing on how to replace a very short hose at the very back of the firewall near the heater inlet. Part of it is hidden betwen the back of the block and the firewall. Can it be replaced without removing the engine?
tip kindel is offline   Reply With Quote
Old 09-12-2007, 04:02 AM   #2
f00g00
Yes it can, it has a spring clamp holding the little boot on so you need a pair of pliers to remove that then take the boot off and replace it with a new one.
Just make sure the engine is stone cold when you do it so you don't burn yourself.
MK3 supra Hose Techniques silicon hoses Micahwc Shops & Part Reviews 8 12-09-2012 09:03 PM
HELP!: 7MGTE engine block info needed barton MKIII Supra 6 04-14-2010 09:28 PM
Picture? Power Steering pressure hose ptomko MKIII Supra 4 10-08-2008 02:19 PM
Replacing Clutch reservoir Hose and fixing rock plate (plastic one) Grandavi MKIII Supra 2 09-29-2008 04:49 AM
Plug or hose came off back of block f00g00 MKIII Supra 3 05-20-2006 11:01 PM
