-   -   7mgte vs. 1jz (http://www.toyota-supra.info/forums/mkiii-supra/9659-7mgte-vs-1jz.html)
zuni 09-12-2007 01:42 AM
7mgte vs. 1jz
i have a 89 mk3 with a turbo 7mgte motor. i am wanting to swap the motor out for a 1jz. my question is, is it going to be a direct fit. Do i need to get the ecu as well for it. and if i were to replace the stock motor mounts with aluminum ones would that work and what are the advantages and dis advantages of them.
zuni 09-14-2007 05:10 AM
noone has any input???
Supra2NR 09-14-2007 05:51 PM
The motor mounts should line up
Not so sure about the crossmember,
There's a lot of threads about this swap
Its not that nobody has any input
I guess they jus don't want to explain the whole thing once again
Jus use the search feature, or try the faq section of the forum
