Old 09-12-2007, 01:42 AM   #1
zuni
zuni's Avatar
zuni is on a distinguished road
Arrow 7mgte vs. 1jz
i have a 89 mk3 with a turbo 7mgte motor. i am wanting to swap the motor out for a 1jz. my question is, is it going to be a direct fit. Do i need to get the ecu as well for it. and if i were to replace the stock motor mounts with aluminum ones would that work and what are the advantages and dis advantages of them.
zuni is offline   Reply With Quote
Old 09-14-2007, 05:10 AM   #2
zuni
zuni's Avatar
Unhappy
noone has any input???
Old 09-14-2007, 05:51 PM   #3
Supra2NR
Supra2NR's Avatar
The motor mounts should line up
Not so sure about the crossmember,
There's a lot of threads about this swap
Its not that nobody has any input
I guess they jus don't want to explain the whole thing once again
Jus use the search feature, or try the faq section of the forum
Twin turbo on 7mgte? supraman121 MKIII Supra 7 08-24-2007 02:12 PM
7mgte and 7mge question supraman121 MKIII Supra 2 01-12-2007 09:09 PM
7mge to 7mgte kallmijonx2 MKIII Supra 2 10-22-2006 12:55 PM
