Old 09-14-2007, 11:45 PM   #1
D_Train
D_Train is on a distinguished road
Default squeeking
My car never squeeks except when I go in reverse. Sounds like a brake squeek, but why would it be in reverse only?
D_Train is offline   Reply With Quote
Old 09-15-2007, 03:44 AM   #2
mrnickleye
mrnickleye's Avatar
The squeek is likely a brake pad, and as the rotor comes around, the pad 'barely' touch a spot on the rotor. This light touch will create a tiny vibration, will will sound squeelish. Got it now on my drivers side rear. Pads and rotor are good. It started when I removed the pads and then put them back.
I(and You) need to remove the pads and apply some brake stop squeel on the back side of the pads that touch the caliper.
squeeking bushing Chomper Non-Generation Specific Questions 0 12-10-2005 12:35 AM
squeeking front suspension Bryan MKIII Supra 3 07-07-2005 12:38 AM
