Old 09-15-2007, 04:56 AM   #1
mkiiisupra
Default Wastegate stuck open
The current turbo on my supra produces boost and continuosly kicks it out the wastegate so i get nothing from it. Was told there is no way to fix it just need a new one.
So i decided to have my spare turbo rebuilt, which has too much play to it and makes noise when you turn it, i guess scrapping the turbo housing.
My question is, since i am already having it rebuilt i figured i may as well have them upgrade the internals in it. If i stick this upgraded turbo on my engine will i risk blowing my engine? Everything else is stock except for a K&N air intake
Old 09-16-2007, 02:27 AM   #2
abhattan
abhattan's Avatar
as long as you don't overboost, you should be all right.
'91 Turbo Targa 5 Spd.
'87 Corolla GT-S 5 Spd
'91 Accord Daily Driver 5 Spd
Old 09-16-2007, 02:30 AM   #3
mkiiisupra
sooo as long as i dont use a boost controller to increase boost it wont push too much through engine?
Old 09-16-2007, 04:51 AM   #4
abhattan
abhattan's Avatar
if your having the turbo slightly modded, up to 10lbs should be safe!
Old 09-16-2007, 05:29 PM   #5
mkiiisupra
ok thanks for the help
Old 09-17-2007, 02:02 AM   #6
OfnaRcR
If your going to upgrade and rebuild your turbo you can get a quality job from the guys at driftmotion although you might already know this. It would probally be around 610 for a rebuild and a turbo that can handle 20 lbs.
Old 09-17-2007, 02:09 AM   #7
mkiiisupra
http://www.turbochargers.com/ going with those guys
since i will be able to drop off turbo and pick it up while i am visiting my family in texas.... know anything about them? also did not see where on drift's site they do the rebuilds if u wanna post a link
Open downpipe? redmaro MKIII Supra 5 08-21-2007 01:14 PM
External Wastegate! teedoff00 MKIII Supra 1 04-11-2007 03:49 AM
Wastegate? drmmr15 MKIII Supra 19 01-16-2007 07:07 PM
gas tank door stuck open tonystarks MKIII Supra 1 05-18-2006 09:59 AM
