Old 09-18-2007, 12:22 PM   #1
87 Supra
87 Supra's Avatar
87 Supra is on a distinguished road
Default Auto Transmission Shifter Question
I just bought another 88 Supra as a parts car yesterday. It runs but it will not go into gear. It’s an auto and the shifter is all loose and acts like it’s busted. Is there anyway to get the car to go into gear if I take off the shifter? I just want to check the trannny out if I can before I start taking the car apart.
87 Supra is offline   Reply With Quote
Old 09-18-2007, 03:42 PM   #2
mrnickleye
mrnickleye's Avatar
I tried a search by found nothing. I read on here some time ago that the bushing the shifter is mounted with gets worn out, and can be easily replaced.
Old 09-18-2007, 03:56 PM   #3
87 Supra
87 Supra's Avatar
Well, the darn thing will go into Park and Neutral but no gears at all. The shifter almost feels like it could fall off the car. I want to check the transmission out and see if it was decent before i take the car apart. Is there some linkage that I can manually put it into gear?
Old 09-18-2007, 05:12 PM   #4
Syris
Syris is on a distinguished road
Yes there is a linkage on the side that you should be able to see while still in the car IIRC. Check your fuses for any blown ones as it might be causing to not want to shift. But have a friend shift from Park to neutral while you are under the car to find exactly which linkage to move.
Syris is offline   Reply With Quote
Old 09-18-2007, 07:20 PM   #5
87 Supra
87 Supra's Avatar
Thanks, i will give it a shot.
86.5 auto transmission removal HELP!!! elmer MKIII Supra 13 04-06-2010 10:41 PM
Auto Transmission Swap big_kahuna89 MKIII Supra 1 06-13-2008 11:13 AM
Auto to Manual transmission? dannydavi MKIII Supra 19 05-18-2007 05:33 AM
Transmission Question???? Dejvid1785 MKIII Supra 4 10-15-2006 03:23 PM
