Old 09-18-2007, 01:32 PM   #1
wyosupra
wyosupra is on a distinguished road
Default Rod Knock??? Why!!!!
Yesturday I finally Finished my HG , and now it sounds like I have a slight rod knock only at about 2000 rpm, but I dont think it was there before, it runs fine and isnt getting any worse, it might have gone away.
ANY SUGGESTIONS??Or why now???
1990 Targa Turbo apexi 3" MHG
FOR SALE!! 1988 Supra Targa Top Turbo
3" Magnaflow
wyosupra is offline   Reply With Quote
Old 09-18-2007, 05:09 PM   #2
Syris
Syris is on a distinguished road
The coolant got down into the bearings from your Blown HG and that has caused your rod knock. You most likely did not drop the oil pan to take a look to make sure though did you?
Syris is offline   Reply With Quote
Old 09-18-2007, 05:46 PM   #3
wyosupra
The oil wasnt a milky color, it ran fine when I pulled the head. Compression was gettung into the cooling system. No I didnt pull the oil pan. Should I???
3" Magnaflow
Old 09-18-2007, 06:57 PM   #4
supramacist
supramacist's Avatar
No need now. The damage is irreversible.
Old 09-18-2007, 11:22 PM   #5
indy
indy is on a distinguished road
might seem dumb but was it low on engine oil at any time?? mine was burning oil and i topped it up and went on a roadtrip and by the time i got into town it started to knock so just always check on that....it cost me an engine ha and by the way u wanna buy a 7mgte block with a bad rod bearing ha
indy is offline   Reply With Quote
Old 09-19-2007, 01:11 PM   #6
wyosupra
The cam caps looked like the engine was oil starved at one time. Now that I have some miles on it, the knock is gone There is a god, im running her in our local 1/8th saturday. I will let you know what I run. Thanks everyone
3" Magnaflow
Engine knock @ 1700-2300 rstutler MKIII Supra 8 03-07-2008 07:36 PM
Rod Knock kewlcoconut MKIII Supra 20 01-13-2006 08:39 PM
