-   -   7mge w/ tubro (http://www.toyota-supra.info/forums/mkiii-supra/9779-7mge-w-tubro.html)
carfanatic89 09-24-2007 12:27 AM
7mge w/ tubro
one of the problems of puting a tubro on a 7 mge is the return of oil to the oil pan, my question is there is a plug on the side of the pan (not the drain plug)couldnt you unscrew the plug and adapt it to recieve the oil after the turbo. i think its on the other side but you could bend a hard line to that side and screw it in????
supraman121 09-24-2007 03:53 AM
Why not just buy one of these thingys and have it return into there?
Well if it isnt pressurised, it might be but if it isnt have someone drill a hole weld a plug and then you can go nuts
http://www.optionimports.com/oilfiblad.html
Supra2NR 09-24-2007 09:38 PM
Even if you get to use the hole on the otherside, how do plan to route the pipes?
Underneath the oil pan?
I'm not sure how much pressure there is in the return
But a slacked line causes oil to build up in the turbo, and causes it smoke and may lead to messing up the seals,
And that's only a slack on the line,
Jus tap the oil pan on the exhaust side of the engine, get sum fitting welded in
So that way ur sure its gonna work,
Rather than spending all that time routing lines to the other side, jus so u can blow ur turbo
carfanatic89 09-27-2007 02:46 AM
Im not adding a tubro to my 7mge, I was just throwing the idea out there to see what yall thought.
