Old 09-29-2007, 05:59 AM   #1
redmaro
Default Question on wire for rewiring KS
I went to my local Radio Shack and they didnt have thin net wire. So I was thinking about using regular electrical 16-18 gauge wire. Is this ok?
I really want to rewire my knock sensor tommorow morning, so fast input would really be nice. Thanks guys. Im going to sodder the wiring and im going to use heat shrink tubbing btw. Or where else can I find thin-net wire?
NOte: Im using the KS rewiring guide from www. supras.com
MK3, Auto, Turbo.
Old 09-29-2007, 01:16 PM   #2
f00g00
nope the write up says that the regular 16-18 ga speaker wire is to extend the shield ground ("because you're not sure where you're going to ground the braided wire at.") so just go to frys and check this wire
http://shop3.outpost.com/product/3550664/#
frys is on 2300 West Baseline Road in tempe, I go there every year on vacation to buy stuff I can't get here in kuwait.
Old 09-29-2007, 04:49 PM   #3
redmaro
Im confused, does the thin net cable have a solid cable in the middle? I dont think i knew what I was looking for, i thought is had to have reagular wire the in the middle.
Is this it?
MK3, Auto, Turbo.
Old 09-29-2007, 05:04 PM   #4
redmaro
I live like 4 hours away from Tempe so its a pretty long drive, but Ive seen stuff that sells for pretty cheap there(I wanna go some day). Im going to check local stores today, i have an idea at what im looking for now. LOL
Thanks.
MK3, Auto, Turbo.
Old 09-30-2007, 12:45 AM   #5
redmaro
Anyone out there?
MK3, Auto, Turbo.
Old 09-30-2007, 02:24 AM   #6
redmaro
Smile
I just found this at Radio Shack, will this work ill just have to cut the ends off. I really want to do this tomorrow morning so help would be nice. Thanks
Link:
http://www.radioshack.com/product/in...rt&tab=summary
MK3, Auto, Turbo.
Old 09-30-2007, 03:26 AM   #7
gomezmk
Why are people rewiring the knock sensor? Has there been problems with the factory wiring?
Old 09-30-2007, 03:31 AM   #8
f00g00
Yes the radio shack wire will work fine and get some regular wire to connect to the shield to extend the ground, the ground point at the back of the intake plenum will probably be fine.
Old 09-30-2007, 04:11 AM   #9
redmaro
Thanks man you great!
MK3, Auto, Turbo.
where and wha color is the speed sensor and rpm signal wire 88Tsupra MKIII Supra 6 03-16-2011 07:48 PM
wire harness question!! 781supraturbo MKIII Supra 2 01-03-2008 09:07 PM
Question for someone who has actually seen the outside rear lock mechanism finaltable MKIII Supra 0 10-22-2007 02:44 PM
Ignition / Wire Harness Question kidsusukigsxr MKIII Supra 2 07-11-2007 12:57 PM
need help: wire coming off A/C compressor - to? theWeezL MKIII Supra 5 05-17-2006 11:26 PM
