Old 09-30-2007, 07:37 PM   #1
red_armie_soviet
red_armie_soviet is on a distinguished road
Default quick question about turbo
so basically i blew the motor from my last supra a 7mgte fuckin rod knock, so im getting a 7mge put into my supra now, wat upgraded parts will i need to swap the turbo from the 7mgte to the 7mge and stuff like that
red_armie_soviet is offline   Reply With Quote
Old 10-02-2007, 05:34 PM   #2
abhattan
abhattan's Avatar
you should use only the block and the head from the 7MGE. And you will have a higher compression ratio after. this is important for turbo! also, switch out the cams.
'91 Turbo Targa 5 Spd.
'87 Corolla GT-S 5 Spd
'91 Accord Daily Driver 5 Spd
Old 10-03-2007, 02:41 AM   #3
From what I've read on here and other various websites, in order to get a 7MGTE out of a 7MGE, you have to swap the exhaust manifold, intake cam, intake manifold (more or less depending on what year 7MGE it is), pistons/piston rings (N/A pistons have a higher compression ratio, turbo works better with lower compression), oil lines running to the block (in the N.A you could probably get away with tapping into the oil pan for the lines), an oil cooler, vacuum lines for the turbo/turbo parts (BOV, etc.). I believe your head should be fine from the N/A, as the valve clearances are the same, and I'm pretty sure the lengths are the same too. With all of the work you'd have to do to make your 7MGE compatible with a Turbo, you're better off getting a 7MGTE and maybe even rebuilding it. Now would be a good time to get your engine how you want, and take care of that headgasket.
I can't think of any other parts, as I have a N/A. I did a little browsing before when I thought about converting to Turbo, but I decided it's smarter to swap it for a 7MGTE; less stuff could go wrong.
If this doesn't help, search the forum. Other people have asked about this kind of work...
Old 10-03-2007, 06:31 AM   #4
redmaro
Seems like a lot of work.
MK3, Auto, Turbo.
Old 10-04-2007, 03:39 AM   #5
Supra2NR
Supra2NR's Avatar
i would jus swap a 7mgte, or jus get a turbo mk3
Turbo lag question. rnoswal MKIII Supra 6 02-12-2006 05:42 AM
Non turbo Kit, quick question Hennessey MKIV Supra 1 02-04-2006 04:47 PM
quick question re: turbo inlet born2drv MKIII Supra 2 01-11-2006 05:02 PM
