Old 10-01-2007, 04:58 AM   #1
supraman121
Default Car started to over heat today.
I was driving back from getting some food and i saw the temp gauge almost in the red so i pulled over and when i pulled into the parking lot the temp gauge dropped back down.. my father thinks the thermostate might be sticking which would cause it to start over heating he thinks when i hit the bump it knocked the thermo loose and it started working normal is this possiable, or could the water pump be going meaning it is working half the time and then it stops working?
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 10-01-2007, 06:19 AM   #2
oowee623
oowee623's Avatar
it could be the thermo, could be the radiator, radiator cap, water pump ect. have replaced the headgasket yet?
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
Old 10-01-2007, 07:42 AM   #3
supraman121
Well the radiator leaks a little bit and i no from where its out the drain plug the radiator cap is also good, waterpump hasnt been replaced no signs of it not working yet and the headgasket hasnt been replaced sence i have had it there arnt any signs of a bhg such as white smoke or milky oil, i replace the coolant like a weak ago i guess i couldnt have put enof coolant in it how many gallons of collant does the stock radiator hold, but i put some more in yesterday and some more in today but it still over heated. And i know it has coolant in it.
K&N Air Filter
Old 10-01-2007, 05:40 PM   #4
Sinistral
Sinistral is on a distinguished road
Mine does this as well, it's a relatively common problem with the MKIII. When the temperature goes up, turn the air on full blast on 85 degrees. I know it's uncomfortable, but for whatever reason it cools the car down. Also, when you come to a red light, slightly rev the engine. Again, not sure how, but it cools down the engine some. Other than that, take it to a shop.
Sinistral is offline   Reply With Quote
Old 10-02-2007, 12:25 AM   #5
oowee623
oowee623's Avatar
i have a bhg but no milky oil but theres exhaust gasses in my radiator, if youre topping off your radiator every now and then you should check for a bhg, and about that leak it may be leaking so much that your cooling system is losing enough water to the point where theres not enough to keep cool
revving the engine increases the fan speed so it blows harder therefore more cooling
and is the water in you overflow tank boiling and blowing out steam? and is your coolant a normal color or brown?
Old 10-02-2007, 09:04 PM   #6
IHateHacks
IHateHacks's Avatar
Run a block test to rule out a blown head gasket. Then pressure test the cooling system. Your overheating vehicle will fail one of these 2 tests.
If you really think the thermostat is bad, change it. They are cheap and easy to do on a 7M. Then take the one you took out and boil it in a pot of water and see if it opens, then you will know for sure if the thermostat is bad or not.
A stock cooling system holds about 9 quarts. Its 8.6 for an 87 non turbo 5spd
87 MK III turbo - AC & Heat Always On Problem robfab MKII Supra 0 08-04-2008 07:12 PM
Heat Consistancy Issues Chambers MKIII Supra 14 04-07-2008 12:52 AM
IC pipes and heat wrap questions. redmaro MKIII Supra 0 09-26-2007 08:00 AM
Heat?? burton51m MKIII Supra 11 02-25-2007 04:28 PM
heat getting into car sd88supra MKIII Supra 7 11-03-2006 12:47 AM
