#1 |
Run a block test to rule out a blown head gasket. Then pressure test the cooling system. Your overheating vehicle will fail one of these 2 tests.
If you really think the thermostat is bad, change it. They are cheap and easy to do on a 7M. Then take the one you took out and boil it in a pot of water and see if it opens, then you will know for sure if the thermostat is bad or not. A stock cooling system holds about 9 quarts. Its 8.6 for an 87 non turbo 5spd Last edited by IHateHacks; 10-02-2007 at 09:14 PM. |
87 MK III turbo - AC & Heat Always On Problem | robfab | MKII Supra | 0 | 08-04-2008 07:12 PM |
Heat Consistancy Issues | Chambers | MKIII Supra | 14 | 04-07-2008 12:52 AM |
IC pipes and heat wrap questions. | redmaro | MKIII Supra | 0 | 09-26-2007 08:00 AM |
Heat?? | burton51m | MKIII Supra | 11 | 02-25-2007 04:28 PM |
heat getting into car | sd88supra | MKIII Supra | 7 | 11-03-2006 12:47 AM |
