Old 10-03-2007, 01:20 PM   #1
ethan12510
ethan12510 is on a distinguished road
Default Car will not start??
ok so i go out to my car and try to start it and i get nothing, but i have power, i hear i clicking sound under the passanger side? i do have a bad AFM, but i thought it would start with a bad afm just run shitty? any hel would be great. Im thinking its the starter. Thanks
ethan12510 is offline   Reply With Quote
Old 10-03-2007, 05:55 PM   #2
supradaddy0803
supradaddy0803's Avatar
I had the same problem with my 86.5. When you try to start it does everything on the dash dim and does the buzzer kind of trail off or does everything just go dark. Also it may be your starter but I would check the easy stuff like battery terminals make sure they are clean and the connectors are tight. Then check to make sure the security isnt stuck on might be the starter cut off. Go out to your door and with your ignition key stick it in the door lock cylinder and turn it to unlock quite a few times then try to start the car. If that doesnt help check your fuses under the hood there is a fusable link that could be bad but you never know.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 10-03-2007, 09:41 PM   #3
atsomepoint
atsomepoint is on a distinguished road
If its clicking its probly not the security system.
I assume youve already tried jumping it?
atsomepoint is offline   Reply With Quote
Old 10-04-2007, 02:56 AM   #4
ethan12510
ya its my starter. i push started it and it started rite up. Now how do i install my new starter? thanks
Old 10-04-2007, 03:29 AM   #5
Supra2NR
Supra2NR's Avatar
disconnect the power wire that goes to it, and the auxilary, or ign
forgot what the othersmaller wire is called, but its easy to see
i believe the starter has two bolts,
taking it off isnt hard, but getting down there is
taking the intake manifold off would be really helpful
Old 10-04-2007, 03:12 PM   #6
ethan12510
so how do i approch it from underneath or from above and i belve that i do not have to correct starter on my car so this should be fun? I should dissconet the battery right? any help would be great
Old 10-04-2007, 03:41 PM   #7
Supra2NR
Supra2NR's Avatar
disconecting the battery would be really helpful
idk how ur gonna approach it
i replaced mine when i had the engine jus put it the car
and my intake manifold was still off, so i did it from the top
power tools would be a real good help with this
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
Car wont start hot carfanatic89 MKIII Supra 41 03-30-2009 10:58 PM
My car decides when it wants to start carfanatic89 MKIII Supra 16 02-12-2008 07:50 PM
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
no start 87supraguy MKIII Supra 5 03-23-2006 07:31 AM
